Running backstay on my PSC 34
For those of you who sail psc 34 & 37 cutter rigged, do you use your running backstay A) always, B) for long reaches, C) only when rigging is strained, D) rarely or E) never.
Sorry for the multiple choice but I'm not sure what's best for our boats. It seems pretty impractical for my sailing around Maine's islands. Should I be using at at every opportunity? I welcome any thoughts, observations or advice. Bob Steneck PSC 34 Alaria Christmas Cove, Maine |
Re: Running backstay on my PSC 34
I'm glad you asked. Just purchased a 37 that the stays'l stay has been removed from as well as the running backs. Wondering what is needed/required/desired when it comes to running backs.
I have a yawl rigged 37 cutter. I will use them when sailing headsail alone or jib and jigger to stabalize the mast in the aft direction. Only in strong winds.
Bob:
We sail a 40, not the 34 or 37, but I imagine the "rules" would be similar. The running backs are meant to keep the mast from "pumping" when the staysail is used. My belief is that in very light air, the stresses a staysail puts on the mast are minimal and the running backs wouldn't be necessary, but then again, we don't use the staysail in light air...so, whenever we roll out the staysail, we rig the windward runner. Is it possible that this is the equivalent of "wearing a belt and suspenders?" I suppose so, but then again, I prefer to see neither my pants nor my mast fall down in public. Fair winds, Roger Lopata JUNO PSC 40 -- #46 |
What Roger said.
Dave Mancini PSC 34 #305 SWAN |
Thank you Roger and everyone for your thoughts.
Actually, I'd rather have my pants fall down in public than my mast fall down half way to Bermuda. As I understand it "pumping" relates to harmonics that can fatigue shrouds. In a blow or long passage I'll be setting my running back stay! It certainly is easy enough. Cheers, Bob Steneck PSC 34 Alaria Christmas Cove, Maine |
I asked Bill Crealock about this a few years ago.He said that the only time the running backs are needed is in heavy winds with the staysail loaded to prevent mast pumping.He then added that he designed the boat for a thinner,lighter mast and the backs were a necessity but that PSC used a much stronger heavier mast so the backs are somewhat redundant.I find with the backs rigged it is difficult to maneuver around them so I only use them when going offshore.
Hope this helps, Dianne and Chuck Burke S/V NiftyNickers C37 #139 |
Most helpful to have the backstory from Bill Crealock himself. I put the same question to Thumper at the factory earlier this year. His advice was the same (mostly, don't bother with the running backs except maybe for peace of mind offshore when it's blowing hard). But it makes all the difference to know that it's about Pacific Seacraft's choice of a more robust mast. Thanks for that.
My conversation with Bill Crealock about the heavier mast referred to the LaFiell spar that was used at that time.I'm not familiar with the new mast that PSC is using.
| All times are GMT -4. The time now is 04:09 AM. |
SEO by vBSEO 3.6.1
