Kiwi Prop - Page 2 - SailNet Community
post #11 of 11 Old 11-07-2012
Wish I never found SN!
SimonV's Avatar
Re: Kiwi Prop
I have a Kiwi prop, next to no drag when under sail and good performance in forward. Putting the box into reverse is like pulling on a hand brake, I would like to find a way to reduce the pitch in reverse, but it works and I try to work with it. As for not having the room for a zinc, you could add a zinc to the hull and bond the shaft from the inside to the zink. its only the shaft you are protecting as the prop is all but inert.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
Kiwi Prop Psc242 Pacific Seacraft 2 02-29-2012 08:14 AM
KIWI Prop jimrafford Gear & Maintenance 5 06-27-2011 12:00 AM
Antifouling and Zincing a Kiwi Prop alex909 Gear & Maintenance 5 04-01-2010 01:52 PM
Kiwi prop --- feathering Johansail Gear & Maintenance 27 03-13-2010 07:49 PM
Kiwi Feathering Prop naiad33 Gear & Maintenance 8 08-05-2009 05:28 AM
HTML code is Off
