Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
  #1
Old 10-19-2012
Norstar's Avatar
Coastal Carolinas
Norstar is on a distinguished road
Kiwi Prop
My 3 blade Max prop has served us well but is starting to give us some issues mainly due to wear. Cost for a rebuild seems excessive compared to replacing with some of the newer props out there. Considering a 3 blade Kiwi prop. The composite blades and simplistic design are appealing as we'll as the ability to change pitch easily. Anyone else out there have any experience with these? I understand reverse is not as much bite as with other props but heck I don't back up allot! Have also heard some reports of noisy under power? Thanks for any feedback.
John S
PSC 34 #201
Norstar
  #2
Old 10-19-2012
Re: Kiwi Prop
Most I know who have them are quite satisfied with the forward performance. On boats with smallish engines the out-of-the-box 'bite' in reverse was enough to stall an idling engine. Adjusting the reverse pitch with some screws seemed to help.
It's odd-looking in some ways, almost like a back-yard cobbled together thing but that's not a big issue.
  #3
Old 10-19-2012
night0wl's Avatar
night0wl is on a distinguished road
Re: Kiwi Prop
I have one...really helped me in reverse vs the fixed 3-blade OEM prop.
One of the best upgrades I've ever made on the boat!
Lost about 0.5 knot - 1 knot under power, however gained about 20-30 sailing days a year. Before, I needed 9-12 knots windspeed to get going...now 7-8 knots and I get somewhere!
S/V Jendai
Beneteau 343
  #4
Old 10-19-2012
Re: Kiwi Prop
Yes, moving to any feathering/folding prop is going to markedly improve the sailing aspect.. but esp feathering props shouldn't (as a rule) cost you performance under power...
  #5
Old 11-01-2012
Psc242 is on a distinguished road
Re: Kiwi Prop
The main problem for us to use the Kiwi prop is the inability to install it with any Zinc to protect the shaft.
I went through the process and could not find a solution.
Jacob
  #6
Old 11-01-2012
PCP PCP is offline
Re: Kiwi Prop
There are some exceptions. Autoprop increases the performance. I heard that the Gori overdrive too
  #7
Old 11-02-2012
orientalnc2010's Avatar
orientalnc2010 is on a distinguished road
Re: Kiwi Prop
Hi Northstar, The problem with the Kiwi is that there is no place to put the prop zinc on a PSC as stated earlier. A possible solution would be to install a hull zinc and connect it to the prop shaft with a shaft brush.
I too liked the KIWI concept. When is spoke to the rep in CA he had no PSC 31's in his data base. He was able to "recommend" the size by the engine hp and displacement.
Regards,
Steve
PSC 31 #125
Ryoko
Oriental, NC
One of the two happiest days in a sailors life
  #8
Old 11-03-2012
Norstar's Avatar
Coastal Carolinas
Re: Kiwi Prop
I was hoping there would be enough space in front of the Kiwi prop to install a donut zinc on the shaft. I'm still on the fence on this prop choice but will need to do something soon. I may just put my spare 2 blade bronze Astral prop back on for now and send my Max Prop back for reconditioning. I'm thinking from the experience of others, that's a costly proposition but maybe my best bet.
John S
PSC 34 #201
Norstar
  #9
Old 11-03-2012
sailak's Avatar
Crealock 37
sailak is on a distinguished road
Re: Kiwi Prop
Jacob
Couldn't you put a donut zinc ahead of the prop?
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
  #10
Old 11-03-2012
Re: Kiwi Prop
Sorry. no.
I have a 1/4" between my cutlass bearing and the prop.
You may post attachments
You may edit your posts
Kiwi Prop Psc242 Pacific Seacraft 2 02-29-2012 08:14 AM
KIWI Prop jimrafford Gear & Maintenance 5 06-27-2011 12:00 AM
Antifouling and Zincing a Kiwi Prop alex909 Gear & Maintenance 5 04-01-2010 01:52 PM
Kiwi prop --- feathering Johansail Gear & Maintenance 27 03-13-2010 07:49 PM
Kiwi Feathering Prop naiad33 Gear & Maintenance 8 08-05-2009 05:28 AM
SEO by vBSEO 3.6.1
