PSC37 Forward Water Tank - Page 2 - SailNet Community
 3Likes
post #11 of 13 Old 07-07-2014
Re: PSC37 Forward Water Tank
On a PSC 37, where are the hose ports located on the forward tank? Are they accessible? I think we have a clogged hose.
Grant Woodside
Sablier
PSC 37, 1994 #272
Purchased March 2014
Sablier is offline
post #12 of 13 Old 07-08-2014
Hi,
On NiftyNickers hull#139 the water inlet connection is on the forward end of the tank and I think accessible from the small compartment under the anchor locker doors.The water outlet in on the rear bottom of the tank and I think accessible by removing the drawers under the v berth.The airvent connection is also at the front of the tank near the inlet connection.If the S/S tank can be removed why not have it repaired it can certainly be welded.If not you could use a flexible neoprene tank such as Vetus sells.
Good luck,
Dianne and Chuck Burke S/V NiftyNickers C37 #139
niftynickers is offline
post #13 of 13 Old 07-09-2014
Hush34's Avatar
The tank is as described by others who have posted. I have one suggestion to offer if you want to avoid all the problems with rebuilding or fabricating a tank.
Look at Vetus...they have flexible tanks and may have one that will fit into the space built in by the factory. You may loose some capacity.
Hush34 is offline
Cal 2-29 forward hatch upgrade & holding tank question bajasurf Cal 13 10-22-2010 09:54 PM
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 06:38 AM
Is the fuel & water tankage on PSC37 enough for ocean voyaging? phboujon Pacific Seacraft 10 08-18-2009 05:26 PM
PSC37 Forward Cabin Under Berth Storage Ideas arisatx Pacific Seacraft 10 03-17-2009 09:45 PM
Refrigeration -Using the water tank as a cooling water source HenryRusty Gear & Maintenance 7 03-29-2007 01:14 AM
HTML code is Off
