PSC34 Gear Reduction Ratio - SailNet Community
post #1 of 4 Old 01-26-2013 Thread Starter
I have a Yanmar 3JH2E engine on my 1994 built PSC34 #274. The tag on the marine gear box reads Kanzaki model TuffTorq #WMGP4. I need the gear reduction ratio for ordering a fixed 3-blade prop. From all what I read in the forum I would assume the ratio is 2.14. Does the tag information contain any coded information about the ratio?
Thanks for your help.
Wolfgang
YankeePSC34 is offline
post #2 of 4 Old 01-26-2013
Re: PSC34 Gear Reduction Ratio
TuffTorq #WMGP4
That turns up tractor parts, can't find that number under any marine Kanzaki gear listings...
Faster is offline
post #3 of 4 Old 01-27-2013
BluesHarp's Avatar
Hi Wolfgang,
We have hull number 279 with the same engine that you have. Our transmission is a Kanzaki model KBW10 with a 2.14:1 reduction ratio. It is embossed in the label.
Neal
BluesHarp is offline
post #4 of 4 Old 01-27-2013 Thread Starter
Thanks Neal. That gives me more ease to believe that the gear box on Yankee has a reduction ratio of 2.14 too. I also checked my original Pacific Seacraft manual. In the propulsion chapter it does not list neither the Yanmar 3JH2E engine, nor the Austral 17 x 10 2-blade prop, nor the 1" shaft diameter, nor the 1"x1.375"x4" cutless bearing, nor the stuffing box, but a reduction ratio of 2.14 for the gearbox. I do believe now that it might be correct and not just a copy/paste information.
Wanted: Volve Penta MS or MSB reverse reduction gear assy erps Gear & Maintenance 3 10-10-2015 05:45 PM
Transmission Gear Ratio for Cal 2-27 bruceboyles Cal 1 05-03-2012 03:17 PM
Max RPM for 3HM35F in a PSC34 mondofromredondo Pacific Seacraft 7 12-06-2008 09:49 AM
PSC34 Chain Stowage DaveMancini Pacific Seacraft 4 01-27-2007 11:51 AM
Volvo MD5 reduction gear JohnGalt Gear & Maintenance 0 07-02-2004 10:44 AM
HTML code is Off
