Go Back   SailNet Community > Boat Builders Row > Pacific Seacraft
  #1
Old 02-01-2013
cvsheppard's Avatar
cvsheppard is on a distinguished road
Forced Air Heating on PSC 34
Does anyone have forced air heating on their PSC 34? If so, where did you mount the blower unit and route the air ducting. I want to buy a Webasto system but can't workout a viable way to install the unit. My PSC is an '89.
Carl
s/v Credence II
PSC 34 #159
Portland, Or
  #2
Old 02-01-2013
jackdale's Avatar
jackdale will become famous soon enough
Re: Forced Air Heating on PSC 34
Have you thought about a hydronic system? You can use engine heat as well as the heat from the diesel furnace. The piping takes up less space than the air ducts and there is the ability to control fan speed in each cabin.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
  #3
Old 02-02-2013
johnharch is on a distinguished road
I have a 91 34 with an Espar forced air heater. The heater is installed up in the cockpit combing on the port side. The duct is routed aft through the lazarette and then forward under the starboard quarter berth between the water tank and the engine compartment. Then under the floor of the chart table and through the locker under the chart table and under the settee. There are two outlets, one under the forward end of the quarter berth and one under the hanging locker. It is all very neatly done and I assume factory installed. I can't imagine retrofitting it.
The fuel line is teed off of the engine fuel line in the engine compartment. This is not really good as it adds a potential for leaking air into the engine fuel. If I ever replace the fuel tank, I will put a separate pick up in it for the heater.
  #4
Old 02-02-2013
outbound is on a distinguished road
have a 2004 PSC34. Espar unit in port cockpit locker all the way aft. Ducting to outlets throughout port side of vessel. Factory installed and works great. Make sure you can vary fan speeds and can control output. even in N.E. late fall sailing can make boat too hot if no way to modulate. If do hydronics have resovior so doesn't cycle so much and rigged with thermostats. Using Webasto hydronic system on the Outbound with separate AC unit for the saloon. . Think Espar may be better choice in small boat like the Crealock as it doesn't take much to keep it toasty. Surprised how low the current draw is.
s/v Hippocampus
Outbound 46, PSC 34
  #5
Old 02-03-2013
cvsheppard's Avatar
Thanks everyone for your posts and comments. It has helped very much in my decision process. The Webascto is not going to work for my situation, so I'll continue my quest and will certainly look into the hydronic systems.
Carl
s/v Credence II
PSC 34 #159
Portland, Or
You may post attachments
You may edit your posts
forced air heater duct material stantale Gear & Maintenance 5 01-22-2011 12:25 AM
Forced air heating delivery question? Petar Gear & Maintenance 1 01-20-2011 11:22 PM
Forced to Champaign SailinCowboy General Discussion (sailing related) 3 07-19-2006 03:30 PM
SEO by vBSEO 3.6.1
