Cockpit Locker Lids - SailNet Community
 2Likes
  • 2 Post By wsmurdoch
post #1 of 5 Old 02-18-2013 Thread Starter
Not Finished Yet
RainDog's Avatar
Cockpit Locker Lids
The hinges on my Lazarette lids are all pulling through the lid. The bolts have pulled all the way through the lid. I need to rebuild the fiberglass and put all new bolts on the hinges.
Has anyone done this? Any advice?
RainDog is offline
post #2 of 5 Old 02-19-2013
Re: Cockpit Locker Lids
If you have room, why not epoxy/glass in some aluminum plates into the lids, then drill and tap them for the new bolts.. then the nuts just become 'locknuts' and the whole assembly should last a long while...
Faster is online now
post #3 of 5 Old 02-19-2013
Location: The house is in Kingsport, TN. Boats are on Watauga Lake and in New Bern, NC
Water got into the plywood core of my starboard cockpit locker lid through the hinge bolts and rotted the wood in the area near the hinge bolts. When I would tighten the bolts, the nuts would just sink in. I used a small hole saw to drill out the interior fiberglass and the wet plywood at each hole leaving the thicker exterior fiberglass intact. I filled the depression with epoxy putty then redrilled the bolt holes. The holes nearest the edges had to be counterbored so that the nuts were depressed and did not strike the locker lip when the lids were closed. I did it to both the port and starboard lids while I was at it.
Bill Murdoch
1988 PSC 34
Irish Eyes
Faster and BluesHarp like this.
wsmurdoch is offline
post #4 of 5 Old 03-21-2013
Maine Dub
34crealock's Avatar
I did what Murdoch did to hatches on a C&C which had the same problem. The repair was still good when I sold her 10 years later.
34crealock is offline
post #5 of 5 Old 04-01-2013
I had this done on my 1996 PSC 37 when I had it refit at PSC in NC. I cannot remember the cost but it wasn't a lot of money. I am think it was about $600.00. That is nothing in sailboat terms.
rwhalen is offline
Origami Paddler - a folding paddle board that can fit in a cockpit locker rhumbunctious General Discussion (sailing related) 15 05-31-2012 02:29 PM
Cockpit seat locker lid restraint ideas jameswilson29 Gear & Maintenance 5 11-12-2011 01:12 AM
Gas tank Locker for cockpit CliffRuckstuhl Gear & Maintenance 3 01-19-2010 08:29 PM
Cockpit Locker & Engine Access Gasketing LittleWingCA Gear & Maintenance 6 01-10-2009 09:53 PM
Ice Box Lids aphil138 Gear & Maintenance 1 10-09-2007 05:58 PM
HTML code is Off
