downwind sail for PSC31 - Page 2 - SailNet Community
 1Likes
post #11 of 31 Old 02-26-2013
Re: downwind sail for PSC31
Originally Posted by RainDog View Post
2) It is easier to set up and take down. Than a roller furler.
And this comment is based on ....?
knuterikt is online now
post #12 of 31 Old 02-26-2013
Not Finished Yet
RainDog's Avatar
THe time it takes to set up and take down my roller furler vs. the time it takes to set up and take down my Asym.
RainDog is offline
post #13 of 31 Old 02-26-2013
The furler for your head sail is not the same as a furler for an asymmetric...
post #14 of 31 Old 02-26-2013 Thread Starter
Summit_Elan's Avatar
I think we've ditched the idea of a furling asymmetric, though that was in my original post. Someone told me that to add a third furler up front, you have to move the other two furling units back in addition to extending the bowsprit, which I don't even have at the moment.
Elan K
SV Hinei'ni
Pacific Seacraft 31 #36
Summit_Elan is offline
post #15 of 31 Old 02-27-2013
Someone is misguiding you...
It is true that to use a asymmetric furler you need some room between the tack point for the asymmetric and the headstay (in front of the foremost stay/ furler). So if your headstay is terminated at the end of the boat (bowsprit/stem) you need add or extend the bowsprit.
But moving the existing ones - why?
post #16 of 31 Old 02-27-2013 Thread Starter
Not sure..
Elan K
SV Hinei'ni
post #17 of 31 Old 02-28-2013 Thread Starter
Wouldn't I need to either extend the top of the mast too or lower the other halyards (not happening) to accommodate another furler?
Elan K
SV Hinei'ni
post #18 of 31 Old 02-28-2013
Not Finished Yet
RainDog's Avatar
This is basically a spinnaker halyard problem. You will have it with any spinnaker arrangement unless you are going to use the same halyard for your genoa and spinnaker.
The normal solution is to install a Spinnaker Bail at the masthead. If you have the LeFiell mast you can get one here:
Masthead Assemblies
knuterikt likes this.
RainDog is offline
post #19 of 31 Old 02-28-2013
Masthead Assemblies
And using the genoa halyard is not a good idea.
Picture of the head of the asymmetric with the top swivel
tack of the same sail
The furler on the bowsprit without sail, the 1:2 tack line led back to the cabin top winch so I can adjust the tack hight and pull the furler out.
The sail get attached to the furler before the furler is attached to the tackline.
Close-up with the furler in position for the solent jib.
Flying the sail with tack eased
post #20 of 31 Old 02-28-2013
Not Finished Yet
RainDog's Avatar
I fly mine from the same halyard as my Genoa for now. I will add spinnaker halyard next time I take down the mast.
You can see pictures here if you are interested.
RainDog is offline
windlass PSC31 NorthstarPSC31 Pacific Seacraft 10 10-24-2011 11:36 PM
2005 Hunter 33. How can I make it sail downwind better? Ninefingers General Discussion (sailing related) 17 09-26-2011 12:09 AM
Upgrading autopilot on PSC31 okapi3 Pacific Seacraft 3 09-13-2011 09:49 AM
PSC31 Core Moisture rlaird Pacific Seacraft 4 12-21-2009 07:51 AM
PSC31 Engine rebuild lsbrodsky Pacific Seacraft 2 01-22-2007 01:34 PM
HTML code is Off
