Fuel tank longevity - Page 3 - SailNet Community
 1Likes
post #21 of 22 Old 04-30-2013
Maine Sail's Avatar
Re: Fuel tank longevity
Just an update of "fuel tank longevity". This morning I pulled a .090 walled factory aluminum tank out of a Sabre 34 MKI that was manufactured in 8 of 1983. The tank was properly installed, kept dry and "isolated" from copper fuel fittings.
The owner was concerned due to the age of the tank and wanted it pulled and replaced. After getting it home and cleaning it up the tank looks about as good as the day it was installed. After a couple gallons of Acetone to clean the interior the tank looks like brand new inside and out. I can't find a single sign of corrosion anywhere and I was in there with my scope camera for about 30 minutes.. One of the threaded tank fittings was leaking so I R&R'd all of them and put fresh clean pipe dope on. I will install a new WEMA sending unit and re-install the tank for what may be another 30 years..
Properly installed aluminum tanks, even thin ones (.090), can last a loooooooong time..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #22 of 22 Old 04-30-2013
When you get your new alum. tank I suggest that you take the tank to a place that applies "Rhino coating" to truck beds and have them apply a coating to the bottom of the tank.The stuff is TOUGH and waterproof.
Dianne and Chuck Burke S/V NiftyNickers C37 #139
34crealock likes this.
niftynickers is offline
Need a new fuel tank AlLorman Pacific Seacraft 26 09-16-2011 12:08 PM
PSC 34 fuel tank mondofromredondo Pacific Seacraft 8 11-17-2009 05:22 PM
fuel tank mike dixon Gear & Maintenance 1 11-05-2009 08:35 AM
11.0 Fuel tank S2 Dave S2 1 08-14-2006 10:30 PM
Fuel tank doalmo Gear & Maintenance 0 10-13-2004 02:39 PM
HTML code is Off
