Anyone with Manson Supreme? - Page 2 - SailNet Community
 1Likes
post #11 of 14 Old 05-02-2013
We carry a Manson supreme 45 and a 30+ Bruce on our older C37. The Manson will tap on the bow, and does want to foul a bit with the Bruce. We LOVE the Manson and since we are doing some repairs to that region, we are planning some modifications. As stated, our boat is older and is pre Pacific Seacraft, so the anchor assembly may have changed.
ellenwhite2 is offline
post #12 of 14 Old 08-19-2013
oceangirl's Avatar
Re: Anyone with Manson Supreme?
Thought I'd add more pics of a 45lb Manson on a 34 PSC on our blog, shows the second anchor roller slot.
RAIN DOG & BUTTERCUP: More anchor pics
~~Ocean Girl~~
~~Mrs. Rain Dog~~
1989 Pacific Seacraft Crealock 34 Hull# 142
oceangirl is offline
The Following User Says Thank You to oceangirl For This Useful Post:
DaveMancini (08-19-2013)
post #13 of 14 Old 08-20-2013
SV Skalliwag #141
brokesailor's Avatar
Oceangirl: off topic but what is the block and tackle at the base of the mast for?
brokesailor is offline
post #14 of 14 Old 08-20-2013
Not Finished Yet
RainDog's Avatar
Originally bought as part of the running backstay. We have a coated wire that runs from the mast to a few feet above deck level. The block and tackle is attached to this and to the padeye on deck. The block and tackle is used to tension the backstay. I have never yet felt the need to rig the runners since I have never seen the slightest hint of mast movement.
I also use this as a preventer. I run it from the middle of the boom to the cleat on the rail and attach it with a webbing loop. It is not really ideal for this, but since we already have it on the boat we have not yet rigged a better solution and it works fine.
Finally it will be used to recover a MOB if ever needed. Run from the middle of the boom it puts this right at the lifeline gate. We could use it to help pull someone up to the gate to get them back onboard.
brokesailor likes this.
RainDog is offline
Manson Supreme Julie303 Gear & Maintenance 78 07-12-2014 04:17 AM
Manson supreme vs Rocna dvdcnl General Discussion (sailing related) 13 06-18-2011 09:41 AM
Manson Supreme 25 or 35??? irwin325cc Gear & Maintenance 40 02-27-2010 05:19 PM
Manson Anchor 45 or 60 lbs jorgenl Gear & Maintenance 155 08-29-2009 01:13 AM
Plus one for the Manson Supreme nk235 Gear & Maintenance 52 10-20-2008 07:56 AM
HTML code is Off
