Electric Windlass on PSC 34 - Page 2 - SailNet Community
post #11 of 14 Old 04-18-2013 Thread Starter
cvsheppard's Avatar
Re: Electric Windlass on PSC 34
So far the best price was at Binnacle at $2077 but I'm not familiar with that site and they wouldn't specify "new" vs "rebuilt" or whatever. Defender has it new for around $2470 and you know what you are getting.
Carl
s/v Credence II
PSC 34 #159
Portland, Or
cvsheppard is offline
post #12 of 14 Old 04-18-2013
The Cayman and Tigres I believe are indentical internally. The Tigres provides the cleat on the top which on a Crealock 34 or 37 is probably not necessary with the anchor cleats that are already provided.
Defender's price on the Cayman is ~$200 less then the Tigres.
I installed the Cayman on Crazy Fish about 15 years ago, have been quite happy with it and can't say I ever missed the cleat provided by the Tigres.
You might also check with Downwind Marine in San Diego and see if they would come up with a better price then Defender.
Marc Hall
Crazy Fish, Crealock 37, Hull 207
San Diego
Crazy Fish - Maintaining, Upgrading and Sailing a Crealock 37
MarcHall is offline
post #13 of 14 Old 05-26-2013
International Bum
Send a message via Skype™ to Ken PSC37 Atlas
Thanks for all the pics and feedback. I'm the new proud owner of an '89 PCS 37, and will be doing the same windlass upgrades as the old one is frozen solid. I like the Tigres and will surely be headed down an electric w/ a manual back up path. 2 questions:
1: Any comments on the wiring? Where did you put the control box. Foot pedal controls, any thoughts on a remote as I will be single handing most of the time?
2. Any issues with the chain stacking and room for chain?
Thanks for your help, Thors pictures have already saved me a ton of time.
SV Atlas
1989 PCS 37 Hull #206
Home Port: Rockland Maine
Ken PSC37 Atlas is offline
post #14 of 14 Old 05-29-2013
Battery Bank on Crazy Fish is under the settee just aft of the bulkhead between the head and the main saloon. 4 T105 fit there after I the shelf installed by PS was removed and a lower one installed.
Cables run there to a switch which is located on the same bulkhead on the far starboard side - back of switch is in the locker behind the head sink. From there they run along the top of the head locker and then above panels in the bunk area in the space created by the hull/deck joint. Cables are 1/0 or larger but I can't remember at the moment.
There is a deck switch mounted a bit aft and a bit to starboard of the windless.
Marc Hall
MarcHall is offline
Using a unidirectional electric windlass GrahamO Seamanship & Navigation 8 09-26-2012 07:41 PM
Electric Windlass Marcvet Gear & Maintenance 7 01-01-2012 03:33 AM
Electric Windlass Questions.... MedSailor Gear & Maintenance 2 04-23-2008 03:30 PM
Install electric windlass orionatc Gear & Maintenance 6 04-12-2003 03:33 AM
Electric windlass - options Guylain Gear & Maintenance 8 05-01-2001 03:48 PM
HTML code is Off
