Electric Windlass on PSC 34 - SailNet Community
post #1 of 14 Old 04-14-2013 Thread Starter
cvsheppard's Avatar
I'm looking to install a new electric windlass on my PSC34 and wondering if anyone out there has already tackled this issue on their 34. I'm concerned about using the same basic platform that my current windlass uses, (I know all the holes will be different) but didn't want to off set the windlass to much in order to line up the chain. It seems that most of the windlass are so much fatter than my Muir Hercules. I really like the Lofrans Tigress but I'm considering the Cayman because it's profile is a better fit. Any thoughts??
Carl
s/v Credence II
PSC 34 #159
Portland, Or
cvsheppard is offline
post #2 of 14 Old 04-14-2013
arisatx's Avatar
Re: Electric Windlass on PSC 34
Carl:
Was considering the same upgrade on our PSC37 from the manual, and I snapped some pics of an electric Muir Storm 2200 on a new PSC (31?) that we saw at Annapolis a few years back.
Note the wedge shaped platform that it sits on. I'm sure the factory could set you up w/one.
Here are some pics:
Regards,
Ted
V42#186
s/v Little Wing
arisatx is offline
post #3 of 14 Old 04-15-2013
I installed an IDEAL Windlass on our 37 back in 2001. Never had a problem. If I can find the pictures will post on the site. Never did pics before so this will be a learning experience. If you can get to the IDEAL website I remember they posted pictures of the installation but that was back in 2001.
S/V SACHEM # 355
sachemgfp is offline
post #4 of 14 Old 04-16-2013
I'm a single hander, so although I really liked the manual windlass that was on my boat, I replaced it with a LoFrans Tigres. I have a Manson Supreme 45lb anchor, 240' of 5/16HT chain. I have only had it all in place for a week but testing around with it I am quite happy.
thor is offline
post #5 of 14 Old 04-16-2013 Thread Starter
cvsheppard's Avatar
Thanks for the replies and pictures. Nice shots of the Muir but I'm going in the direction of a horizontal mount. Thor, its good to hear the Tigres works on the PSC, that's really what I wanted to hear. I also found that a PSC 31 "Cool Change" had fit a Tigres on his boat on the recommendation from the folks at Pacific Seacraft. Lofrans Tigres it is. thanks
Carl
s/v Credence II
PSC 34 #159
Portland, Or
post #6 of 14 Old 04-16-2013
I can get you some pictures later today.
thor is offline
post #7 of 14 Old 04-16-2013 Thread Starter
cvsheppard's Avatar
That would be very nice if not to much trouble, thank you. I'm a cutter rig, and one of my concerns was being able to remove the back cover for servicing. It would approximately be just a few inches forward of the deck hardware for the staysail. I've since decided not to make that an issue.
Carl
s/v Credence II
PSC 34 #159
Portland, Or
post #8 of 14 Old 04-17-2013
Had trouble uploading pics so put them on this blog thing. Let me know if there are any others you would like. One primary difference is that my boat is not cutter rigged. Its a sloop with a solent stay. I did try and get you some pictures that you cold spatially relate to your boat. Hopefully of some use.
Anchoring System | SV Brigit
thor is offline
post #9 of 14 Old 04-17-2013 Thread Starter
cvsheppard's Avatar
Thor,
Thanks for the pics, they were perfect for my needs. Sounds like we are on the same track for the anchoring system. I too bought the Manson with 175ft of 5/16 HT and 260ft of rode. The tigres will be the final piece and the remote will be the cherry on top. Thanks for all the help.
Carl
s/v Credence II
PSC 34 #159
Portland, Or
post #10 of 14 Old 04-18-2013
pc237
where did youall find the best price on the windlass units?thanks
pc37howard is offline
Using a unidirectional electric windlass GrahamO Seamanship & Navigation 8 09-26-2012 07:41 PM
Electric Windlass Marcvet Gear & Maintenance 7 01-01-2012 03:33 AM
Electric Windlass Questions.... MedSailor Gear & Maintenance 2 04-23-2008 03:30 PM
Install electric windlass orionatc Gear & Maintenance 6 04-12-2003 03:33 AM
Electric windlass - options Guylain Gear & Maintenance 8 05-01-2001 03:48 PM
HTML code is Off
