Keel Bolt Questions from new owner - Page 2 - SailNet Community
post #11 of 15 Old 08-30-2013
radcat's Avatar
Re: Keel Bolt Questions from new owner
Ken,
Did you take any pics after you cleaned out the gelcoat? I would be interested in seeing what the area in the glass around the keel bolts looked like.
Radcat
PS 37
Hull# 210
radcat is offline
post #12 of 15 Old 09-03-2013 Thread Starter
International Bum
Send a message via Skype™ to Ken PSC37 Atlas
Sorry, I haven't scraped the gel coat off yet. I figured this was a better winter job, and didn't want to start on it during the season. If I do it this winter I'll take some pictures.
Did you relocate your bilge or set it up differently to get it to drain completely? I've got the same issue and if I redo the area, I'm going to find some way to lower the pump.
SV Atlas
1989 PCS 37 Hull #206
Home Port: Rockland Maine
Ken PSC37 Atlas is offline
post #13 of 15 Old 09-04-2013
radcat's Avatar
I havenít figured out how to level the bilge yet.* To be effective, the bilge would have to gently slope from aft to forward.* The problem is doing this without adversely affecting something else.* This could probably be done with glass, but I donít have any experience with that. *Another project for another day.* My immediate problem is fixing the mess the guy made when he re-gelcoated the area under the tank.* The first application cracked in several places.* I suspect it was applied too thick, got too hot, shrunk up and cracked.* His fix was to lay in some more gelcoat which also has some hairline cracks.* I donít want to just keep laying in gelcoat.* I think grinding out and fixing each crack is the best thing to do at this point.* *
Radcat
PS 37
Hull# 210
radcat is offline
The Following User Says Thank You to radcat For This Useful Post:
Ken PSC37 Atlas (09-05-2013)
post #14 of 15 Old 09-09-2013
Is your fuel tank aluminum? My 1992 PSC 34 is and if bilge water can complete the circuit with your SS keel bolts you may get pitting in the tank. I pulled my tank and had to have plates welded onto my tank. I then epoxied over the bolts in a way similar to what you show in your photos. I think that's an excellent way to prevent a bimetal reaction.
Bob Steneck
Alaria PSC 34
Christmas Cove, Maine
steneck is offline
post #15 of 15 Old 09-09-2013
radcat's Avatar
Thanks Bob. The current plan is to cut off the extra threads so there is no contact and apply gelcoat to the tops. Then I get to fix all the cracks the installer left behind. However, the end is in sight. The launch day is next Wednesday.
Radcat
PS 37
Hull# 210
radcat is offline
Tags
keel bolts
Keel J bolt replacement in lead keel funjohnson Gear & Maintenance 26 01-19-2013 09:01 AM
25' Catalina Keel Bolt tklinck C25 and 250 2 09-10-2011 12:10 PM
Keel bolt replacement Qben Tartan 3 02-10-2011 07:24 PM
Keel Bolt Question Neicy Gear & Maintenance 12 03-31-2009 10:43 AM
Keel Bolt, Mirage 30 PegasusX Gear & Maintenance 0 09-05-2006 06:48 PM
HTML code is Off
