-   Pacific Seacraft (http://www.sailnet.com/forums/pacific-seacraft/)
-   -   Keel Bolt Questions from new owner (http://www.sailnet.com/forums/pacific-seacraft/99881-keel-bolt-questions-new-owner.html)
Ken PSC37 Atlas 05-26-2013 01:23 PM
2 Attachment(s)
I'm a new owner of a '89 PCS 37 Hull #206. It is going to be a lot of fun / work...
Like most new owners I started by doing something foolish. Asking a lot of questions I might not want to know the answer to like "Whats in the bilge?" So as part of an effort to clean the boat up and learn her hidden secrets I cleaned out the bilge and wiped out all the old crud and gunk down there.
What I found were the keel bolts, but there were some stress cracks around them. You can see from the pictures there doesn't seem to be any rust / corrosion (should be stainless and there isn't much oxygen in the area)
Has anyone else seen this? I'm not overly worried the keel is going to fall off tomorrow, but I want to be planning a fix for winter? Any ideas or experiences?
As always, thank you for your help!!!!
kd3pc 05-26-2013 02:16 PM
Re: Keel Bolt Questions from new owner
Looks pretty daggoned nice for an "old" boat...what you are seeing is some "filler" or thickened paint/epoxy that has been placed around them to pretty up the bilge. I would chip it and see if it is fiberglass or some sort of caulking (as it appears..in the photos). But that is me, curiosity killed the cat. Now that it is cleaned, you can just leave it and monitor it easy for any change in color texture and condition.
Were there problems, you would see a lot of flaking off of said stuff, as well as rust stains/trails
My guess is that you could chip/scrape this off and find fairly pristine nuts on those keel bolts.
Cleaning the bilge was not foolish, actually the opposite. You need to know what is there and remove in crud/stuff/coins/tools/etc that lives there. The switches and pumps will thank you and the smell of that stuff can be annoying.
You are good to go, enjoy the holiday.
AlLorman 05-26-2013 05:30 PM
I think you do want to get whatever it is off the nuts and bolts at a minimum. Stainless steel is only stainless when it has access to oxygen and those nuts don't seem to.
radcat 06-19-2013 03:42 PM
Congratulations on the new boat. I also have an 89. I apologize for this late response; I have been pretty busy trying to get my boat back in the water. What you are seeing is a protective layer of gelcoat over the bolts that was applied at the factory. When PSC gets a boat in to repair, they remove the old bolt gelcoat, inspect and reapply. This is what Thumper told me when I asked him the same question. He did not recommend trying to check the torque on the bolts, but I will tweak them a little to make sure they are not loose. He also recommended taking pictures of the cleaned bolts for future reference. I am getting ready to do this inspection this weekend before I install the new fuel tank. Something else to watch out for in the bilge is peeling gelcoat. I plan to scrap the loose stuff out of the bilge and go back with three coats of epoxy hull barrier coating.
Ken PSC37 Atlas 06-19-2013 04:07 PM
Radcat,
Thanks for the info, take some pictures if you get into it this weekend. I'd be interested in seeing how it comes out and what another boat looks like. I have a new fuel tank on the radar as well. Mine was repaired with a weld, but I'm thinking replacing it should be on my longer term project list.
Ken
34crealock 06-19-2013 04:15 PM
Re: Keel Bolt Questions from new owner/ slight drift
Anyone know if 34 and 37 use the same fuel tank?:confused:
radcat 06-25-2013 09:09 AM
2 Attachment(s)
There is a long lead time on fuel tanks so I would order well in advance. I got the gelcoat off of a few of the bolts. As Thumper predicted they looked fine. I took these shots right after I scrapped them. I still have a lot of work to do in that bilge. As you can see, there is a fair amount of delaminated glass and gelcoat that has to be replaced. If you remove the tank and find the same thing, be careful when removing the glass mat so you don't damage the copper SSB counterpoise. I would also remove all the stuff from the bottom once you get started. Some of it looked ok but was actually wet underneath.
Psc242 06-26-2013 06:47 PM
It looks to me that the delaminated layers were installed by previous owner when he added the copper for the ssb. I will remove all this staff, clean it and use a kiss cable instead. there is nothing to repair.
MarcHall 06-26-2013 10:50 PM
The Pacific Seacraft installed SSB counterpoise works really well.
As it is already installed I would keep it.
Marc Hall
Crazy Fish, Crealock 37, Hull 207
Crazy Fish - Maintaining, Upgrading and Sailing a Crealock 37
radcat 06-27-2013 02:03 AM
1 Attachment(s)
I'll keep the copper, but the half inch of gelcoat/5200 under the bilge pump won't go back. The pump suction was so high that the bilge area under the tank never drained. Check out the pic. There has to be a better way to mount the pump.
