Sizes of genoas - Page 2 - SailNet Community
 1Likes
post #11 of 19 Old 07-10-2013
overbored's Avatar
Re: Sizes of genoas
Originally Posted by jgeissinger View Post
To ditto Shnool above, there is absolutely nothing wrong with filing a protest for a suspected equipment violation. That being said, it is far more likely that your measurements are not accurate. I've never heard of a sail maker making a 160% (or 162%) genoa. 150% is the common measurement, with 155% allowed as the max to account for stretch and variations. It is easy to be slightly off when you measure the 90 degree angle at the luff to get the accurate LP measurement. Something more obvious, like a 170% (which are occasionally made) might be more apparent. I would bet money you have a 155%.
The only reason to make a sail to a 155 is to race PHRF
PHRF racers do not buy a sail cut to 150 and wait for it to stretch to a 155, if it is stretched that much it is wasted. we buy a sail cut right to the max measurement and they really do not stretch but if they do you have it re-cut. the LP measurement is the easiest measurement to preform put the tape end on the clew and measure the smallest length you can get at the luff by moving the tape up and down the luff
"GOLD RUSH" PRINDLE 16
overbored is online now
post #12 of 19 Old 07-10-2013
Re: Sizes of genoas
In reply to Aelkin: It is silly to get in a pissing match on an internet forum, and I try to avoid it. That being said, the largest "standard" genoa on virtually all boats is 150%. Go to the Sailrite sailplan database, which is essentially the data used by sailmakers, and look up your boat. I'm not just making this stuff up.
P.S. I have been an official measurer for two different classes of one design boats and sort of know what I'm talking about.
jgeissinger is offline
post #13 of 19 Old 07-10-2013
overbored's Avatar
Re: Sizes of genoas
not really a pissing contest, you are talking about cruising boats and the thread is about sizing a sail for racing PHRF . raced with your Sail Rite sail lately. ask any sailmaker how many racers have them make a 150 when they are allowed to have a 155 without taking a rating points hit.
One design is way different then PHRF. when racing PHRF many One designs are allowed to use a 155 even when the one design only allows the stock sails
post #14 of 19 Old 07-10-2013
Re: Sizes of genoas
The reply wasn't directed to you. I was not talking about cruising boats, and I was not talking about Sailrite sails. Their sailplan database is a very useful and valuable tool. I am sorry I ever tried to give helpful advice to the OP. Later.
post #15 of 19 Old 07-10-2013
Not Finished Yet
RainDog's Avatar
Re: Sizes of genoas
In the causal racing I have done people lie through their teeth on their handicapt forms. Granted some of that might be because it is easier to make something up than to find out the real answer.
Challenging a BS form seems honorable to me, but splitting hairs between 160 and 162 seems kind of lame in a casual race.
RainDog is offline
post #16 of 19 Old 07-10-2013
blt2ski's Avatar
Re: Sizes of genoas
Locally the % is based on fortriangle area, no the LP! My max LP is 153, but I get 155% of my foretriangle area! So My sail maker made me an LP of 155, ended up with a code 6 jib, so got hit with a -3 rating! not what I really wanted frankly. But that is how it goes.
I would have to do some looking in the local rules myself, but a 155.1 to 160 or so would be a -3 hit, a sail larger than 160.1 would be a -6.........
Spin and main sail areas are equal, in that you get a certain size based on a given triangle. Spin is 160% of the J and I square measure, IIRC about 120% of the e and P triangle for the main, including the roach measure.
Locally if racing 1d, you need those sails, but if strickly phrf, you can have another set of sails that meets the phrf rules. So if 2d is a 110% jib, you can use a 155% if racing phrf rules. OR where the 1d requires say dacron sails, you can have string sails in a phrf race.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #17 of 19 Old 07-10-2013 Thread Starter
Re: Sizes of genoas
I appreciate all your comments, more minutes from second place, they get angrier.
We love racing, and I wanna be as legal as possible, after your comments, I'm sure
we arernīt goig to have any problems whith the 162%.
Progreso, in Yucatan, has the best wind around the yucatan Peninsula. WE have a club races whit about 20 to 25 boats.
any time that you want to come, your are welcome.
Jose Palma
Tactician of maravilloso
huges 38 mk 1
Maravilloso is offline
post #18 of 19 Old 07-16-2013
paulk's Avatar
Re: Sizes of genoas
People have suggested that measuring sails can be fraught with errors. That is why there is often a single measurer in a PHRF zone whose job it is to measure each sail that needs it. (Usually people take the sailmaker's word for it being 100%, 130%, or whatever.) Since the % of the jib is theoretically calculated based on the size of the actual foretriangle, it might make sense to measure THAT first. Raking your mast will make the fortriangle area smaller, for example. That might increase the % of your jib in relation to it. Making the mast form more of a right angle to the deck should make the foretriangle larger, so your jib would have a smaller %. Even so, as others have noted, the difference in ratings is in the range of +/- three seconds per mile: not huge. Different wave conditions could have a bigger effect on boats in your fleet than that.
paulk is offline
post #19 of 19 Old 07-18-2013
Re: Sizes of genoas
this is why racing has fallen into difficult times..true get measurement correct.but petty ass complaints should require a remeasurment of complainers as well as defendant...suggesting someone is a cheat is wrong.&has hurt the sport..
tidewaterv is offline
Tags
genoa , racinng
Winch Sizes thisisus Gear & Maintenance 5 07-18-2013 09:35 PM
Why 3 Genoas? Madhatter23 Gear & Maintenance 12 02-08-2011 02:52 PM
halyard sizes???? twisted23 Gear & Maintenance 13 10-06-2010 07:21 AM
Mixing different AGM sizes and brands voice3 Gear & Maintenance 4 06-01-2009 12:05 PM
Flax packing sizes nk235 Gear & Maintenance 2 04-08-2009 08:02 AM
