Effect of shifting weight - Page 2 - SailNet Community
 2Likes
post #11 of 13 Old 09-13-2013
Senior Smart Aleck
jameswilson29's Avatar
Re: Effect of shifting weight
I store my two anchors and rodes in the cockpit locker. There are still readily accessible and the weight is lower and closer to the center of the boat.
I removed the hangars from the bow pulpit shortly after I bought the boat, both because the anchor was snagging the sails and because of the weight issue. The hot water heater and much unnecessary gear and supplies were also removed. As a result, my boat rides higher in the water and seems more balanced.
If you ever cruise, consider how the additional weight of your full water tank and full fuel tank, full icebox, food and additional supplies will affect the balance of the boat.
Low, centered and balanced is best!
jameswilson29 is offline
post #12 of 13 Old 09-13-2013
Remember you're a womble
PaulinVictoria's Avatar
Well if you want to pass other boats, sail faster than them or only try to pass slower boats
I don't think moving your anchor is going to make a huge difference compared to everything else you could be doing. Just make sure that should you actually pass another boat then you are looking as casual as you can.
SchockT likes this.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #13 of 13 Old 09-13-2013
I don't discuss my member
zz4gta's Avatar
The answer is YES, it will make a difference.
Why not take one anchor off the boat?
Merit 25 # 764 "Audrey"
zz4gta is offline
Effect of the effect of the BP oil spill on Gulf Coast marine industry knothead Cruising & Liveaboard Forum 0 09-13-2010 08:23 PM
Design Weight vs. Actual Weight.. paul77 Boat Review and Purchase Forum 16 11-08-2007 01:19 AM
ratio of keel weight to total weight mightyhorton General Discussion (sailing related) 7 07-11-2007 04:37 PM
Displaced weight vs Dry Weight mikehoyt Gear & Maintenance 7 10-23-2002 06:01 AM
