Effect of shifting weight - SailNet Community
 2Likes
post #1 of 13 Old 09-12-2013 Thread Starter
Another newbie question! Bubblehead mentioned removing excess weight in another thread, so naturally, an LED light bulb went off after that comment.
I have stripped down as much non-essential gear as possible on my boat. However, I do have two danforth anchors that (fortunately) I have yet to use. One is on the bow pulpit, the other on the stern pulpit. I am thinking of removing them from the pulpits, and finding a way of securing them centered on the boat down in the cabin. Will this have a positive effect on performance? If so, is it worth moving the anchors at all?
Thanks.
FirstCandC is offline
post #2 of 13 Old 09-12-2013
pete
I am a firm believer that am anchor is a safety item ! One that should never be overlooked ! Readily available to use in case of going aground ,,
beachmont is offline
post #3 of 13 Old 09-12-2013
Moderator
Jeff_H's Avatar
Re: Effect of shifting weight
It should help in choppy conditions. Most race rules call for anchors and that required equipment be stored in their normal position. That would allow you to remove the stern anchor,but the bow anchor would need confirmation from the class measurer.
Jeff_H is offline
post #4 of 13 Old 09-12-2013
Some class rules also require you have a full compliment of cruising gear right down to the number of plates and cutlery. One of the classes I race in has this rule though they don't have lifelines or stanchions so they can trim to a better sheeting angle and a teritary benefit is there is less drag if the rail is buried. They usually do put them back on if going cruising.
ScottUK is offline
post #5 of 13 Old 09-12-2013
Rocket Scientist
Cap'n Russ's Avatar
I have been in races where the wind died and we had to drop anchor because the current was taking us away from our next mark. If you do remove it from the pulpit, make sure you have it somewhere that allows easy access if you need it.
Cap'n Russ is offline
post #6 of 13 Old 09-12-2013
SchockT's Avatar
Very few racers that I know carry their anchor on the bow. Not only is it the worst place to have the weight, but it also tends to snag and rip spinnakers. There is no rule that I know of that dictates where you must carry your anchor, only that you have one on board.
Excessive weight in the ends of the boat tends to cause the boat to "hobby horse" Through waves, and there are other weight balance considerations depending on your specific boat.
jameswilson29 likes this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #7 of 13 Old 09-13-2013
Remember you're a womble
PaulinVictoria's Avatar
Are you racing? If no, don't worry about it.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #8 of 13 Old 09-13-2013
Forgive me for even thinking about this but since the OP did say Danforth and a Danforth has those nice big flat flukes on it...
Logically, why couldn't you drill the plates out like swiss cheese, cutting out maybe 20% of the metal and still having an anchor that worked exactly the same way, by digging in the flukes? Coupla pounds off the boat, fast job in any machine shop.
No?
hellosailor is offline
post #9 of 13 Old 09-13-2013
SchockT's Avatar
Obviously, but he is asking the question in the Racing Forum....
Hull#101
SchockT is offline
post #10 of 13 Old 09-13-2013 Thread Starter
I am not racing, but I want to pass some boats!
Sorry if I posted in the wrong forum.
Effect of the effect of the BP oil spill on Gulf Coast marine industry knothead Cruising & Liveaboard Forum 0 09-13-2010 07:23 PM
Design Weight vs. Actual Weight.. paul77 Boat Review and Purchase Forum 16 11-08-2007 12:19 AM
ratio of keel weight to total weight mightyhorton General Discussion (sailing related) 7 07-11-2007 03:37 PM
Displaced weight vs Dry Weight mikehoyt Gear & Maintenance 7 10-23-2002 05:01 AM
