Go Back   SailNet Community > General Interest Forums > Racing
Old 08-23-2005
Bootydawg is on a distinguished road
Rules - Luffing v Sailing above proper course
OK - so here''s an issue I came across at the weekend...
3 boats: L to leaward of C (central) who was leaward of W.
I was in W. C saw a gap between W and L and went for it. She obtained an overlap on W within two boat lengths to leward of her - consequently, she had no luffing rights on W and could not sail above her proper course.
L did have luffing rights and squeezed C up onto W. Was C sailing above her proper course as a result of being luffed by L? C gave W enough room to respond but W did not want to respond as C had no luffing rights. Should C have responded to L''s luff by saying that she could go no further as W was an obstruction?
Any thoughts would be gratefully received!
Thanks...
Old 08-23-2005
geohan is on a distinguished road
Bootydawg.....First let me say I''m no expert but it seems to me that RRS18.5 Passing a Continuing Obstruction, applies because it is in Section C which takes precedence over Sections A and B. Therefore if C obtained the overlap from clear astern and if at the time there was room to do so, W is obligated to give her room as long as C''s obstruction, L, remains. This is not to say that C can luff W unless forced up by L. That''s just the way it looks from here.
George
Old 09-09-2005
aflanigan is on a distinguished road
Very interesting scenario. You can look at this from lots of different ways.
Geohan cites rule 18.5, but this rule only says that in passing a continuing obstruction (a seawall? An overlapped boat one is obligated to give room to/keep clear of?) rules 18.2(b) and (c) don''t apply. Presumably, 18.2(a) still applies, and might be controlling. But which boat constitutes the obstruction? L? C, based on how W obtained overlap?
Based on pure fair play principles, I''d have to say we need one more piece of information: Were W and L overlapped prior to C squeezing between them? If so, L had luffing rights over W, and C''s intervention should not change the fact. Conversely, if W was clear ahead, C''s intervention should not grant rights to L over W that it otherwise would not have but for the presence of C.
The other interesting aspect of this is when you see this situation prior to the start. I think the answer in this case is straightforward; before the start there is no "proper course" so L can take up any number of boats to windward regardless of how the overlaps are established.
Allen Flanigan
Cats on Board slosharron Living Aboard 49 3 Weeks Ago 12:35 PM
sailing schools-vs-seat of your pants learning to sail tybeefolk Learning to Sail 25 02-16-2010 12:50 PM
Another proper course question langousta Racing 11 12-27-2005 05:33 AM
SAILING IN THE AEGEAN OLYMPICYACHTS Chartering 0 11-20-2002 12:54 PM
ISAF Eligibility Requirements paulk Racing 4 02-05-2001 11:25 AM
