08-13-2006
Sometimes light air is flukey. Someone else can get a puff that completely misses you, twenty feet away. It can be very frustrating. Like your experience with the Cape Dory, we had a Beneteau 36.7 pass us once. It hasn't happened again since, but at the time there was nothing I could do but watch them ease by. What to do in any case? All the standard light-air stuff you read in the how-to books. Not too tight on the halyards, downhaul, outhaul or sheets. (This goes for the jib too.) Ease off any backstay tension so the mast isn't bent (you want almost baggy sails that will provide more power to drive through the inevitable powerboat slop.) DON'T PINCH! Keep the boat moving, even if you have to drive off a bit. Move your jib fairleads forward so that the jib luffs evenly from top to bottom. Try to steer as little as possible - it slows the boat. Use crew weight to heel the boat a little, so the weight of the sails helps keep them curved and full. Sometimes a little heel helps to reduce wetted surface, which can help you go faster too. (This depends on the hull shape. 420's are usually sailed flat, for example.) It may also help to move people forward, out of the cockpit. Doing this can lift the big, flat aft surfaces out of the water, further reducing wetted surface. Grouping your crew together with their weight as near as possible to the keel (usually right aft of the mast) will also help reduce hobbyhorsing in waves, which can slow you down. In a Wednesday night fun race it may be tough to get crew to go below, but it might also be faster to get their weight down. Once they're in place, make sure crew stay put. Moving around slows the boat. Doing these things can help when that catspaw hits to make sure you'll be the one grinning.
