Blogs
Go Back   SailNet Community > General Interest Forums > Racing
User Name
Old 02-10-2002
paulk paulk is offline
paulk is on a distinguished road
Jaws up or jaws down?
The spinnaker sheet discussion below has started a side-issue about the favored direction of the spinnaker pole jaws on the mast and guy. I rig mine jaws down for a number of reasons: 1/So that inadvertent releasing of the jaws doesn''t bean someone on the foredeck, 2/ so that the guy''s pressure (when the sail is pulling up, the way we like it to) doesn''t bind the pin so it won''t release, 3/ so that the guy tends to fall out (due to gravity) when the jaws are opened*, 4/so the pole doesn''t have to be rotated to be dropped and locked into its deck chocks. 5/so you can open the jaws, hook the pole to the mast and not have to continue holiding it up while you trigger the pin shut. We sail a fractionally rigged J/36 with a 1000 square-foot chute on a 65'' mast. Sometimes it blows hard enough for us to use double sheets and guys. What do you do?
*This may work especially well on Long Island Sound because of the generally light wind, too.
Old 02-11-2002
Jeff_H's Avatar
Jeff_H Jeff_H is offline
Moderator
Jeff_H will become famous soon enough
I have been asking around town and I have yet to find anyone who has sailed on a boat with the jaws down. That includes one ex-America''s Cup crew man. I thought maybe the guys who race offshore might have sailed on boats with jaws down. In the past couple weeks I have yet to find a person who sailed on a boat that rigged the pole jaws up, although I liked the New Zealander''s answer that you must be a Kiwi and it only looks upside down from here.
I was also taken by your comment that the chute on the J-36 that you race on is 1000 square feet. The normal J36 chute is just over 500 sqare feet. Are you guys flying a masthead chute with the original penalty pole? If so what did you do to the rig to take the side loads of the chute? I am halfway considering going to a masthead chute fro cruising. (It kills your rating for racing except under IMS.)
Old 02-11-2002
Jeff_H's Avatar
Moderator
OOOPS, that was supposed to read,"In the past couple weeks I have yet to find a person who sailed on a boat that rigged the pole jaws DOWN"
Old 02-11-2002
davidk davidk is offline
davidk is on a distinguished road
I''m the one who asked the question about the sheets & guys in the first place. You''ll be pleased to hear I''ve confirmed with spar and sail maker and we will be free to rig jaws up or down! Our pole ends are the trigger type which lock open until you bang them in when they fire (mind your pinkie) ... Would that influence any one''s decision to go jaws up or down? (splitting hairs!)
More seriously can you take me through the gear you rig on each of the four sheet/guy ends at the clew end? Some of the previous answers were not at all clear. The terms used were maybe americanisms, but I have tested them out and not even professional riggers in UK could understand!
Old 02-11-2002
Jeff_H's Avatar
Moderator
I am probably the perveyor of the terminology conundrums in question. Starting simple:
-''Tack'' is the corner of the chute at the pole.
-''Clew'' is the other corner of the chute.
-''Guy'' is the line that attaches to the tack of the chute passing through the pole end.
-''Sheet'' the line that is attached to the clew on the chute and runs aft to leeward.
-''Lazy sheet'' is the sheet on the windward side of the boat and which is not in use because the guy is being used.
-''Lazy guy'' is the guy on the leeward side of the boat and which is not in use because the guy is being used.
-''Pole lift'' is a halyard that lifts the outboard (forward) end of the pole.
-Pole downhaul'' is a line or tackle located at the base of the mast that pulls downward on a pole end to keep it from ''skying'' or rising uncontrollably.
-''Foreguy'' is a line that pulls down on the spinacker pole from below and foreward that is used instead of a pole downhaul. It stabilizes the pole end better but requires adjustment everytime the pole is adjusted.
-''Biddle'' are the two cable systems that are attached to the pole (one up and one down) that the pole lift and pole downhaul (or foreguy) attach to.
-''Twing'' is a line or tackle that has a block or fairlead on the end. The twing is located at the normal position for the guy lead block (i.e. half way between the spinsheet lead block and the shrouds). When you jibe twing is tensioned on the spinsheet pulling it down to the deck at the proper lead for the guy. When you use twings you don''t use separate guys.
In terms of harware, when you use lazy sheets and guys, the sheets should have a larger bail on the snap shackles so that the guy can be attached to that bail with its own snapshackle. In lighter winds or on long legs, the lazy guy is removed from the sheet so that its weight won''t affect the flying shape of the chute.
I am not sure if I used any other terms but those are the one''s I think I used.
Old 02-14-2002
Checked my info on J/36''s sail areas. J/Boats brochure states 1000 sq'' for the spinnaker. Though I haven''t taken out my tape measure, our I measurement is 44'' and J is 14. After seeing the way it drapes on the forestay in a typical Long Island Sound summer afternoon, our chute has to be closer to 1000 than to 500 aquare feet. Have daydreamed about a masthead chute, but the one we have has pulled us up to 13 knots, and, as suggested, we don''t want to pretzle the top 12 feet of the mast, either. Now, about those pole jaws...
Old 02-21-2002
tiz_1 tiz_1 is offline
tiz_1 is on a distinguished road
You want the outboard end (at the tack of the spinnaker) to have the jaw opening facing up. With the jaw facing down, in a gybe, the pole will not drop off the guy and swing to the new guy. It will hang up on the old guy. This assumes you do dip-pole gybes. Jaw down ends would probably make end-for-end gybes harder as well.
If there is a risk of having the pole drop off the guy unexpectedly and hurt someone on the foredeck you should have the jaw serviced so it is reliable. Also, the pole should not drop as you should be using a topping lift to support it.
If you find that the guy will not lift out of the pole in light air you may have to ease it slightly once the pole jaw is opened. In more air the sail should want to lift, and will pull the guy up out of the jaw once opened.
The mast end jaw opening may go up or down, based on the mast ring size. If the ring is too small the jaw may bind or break when the pole is let down. I usually keep both my jaw end openings facing up on a Cal 40.
--Kevin
Old 02-24-2002
BenDaniels BenDaniels is offline
BenDaniels is on a distinguished road
Kevin, I think you explained it very, very well. However, with a pole outfitted the same way on each end and with matching bridles for end-to-end jibes, the tendency for someone new to is to use it "upside down"...it seems more logical. This happened on my current boat with a new foredeck, and after he could not get the outboard end up and free of the rising (old) guy; we ended up with a ruined mast car. The pole mast end twisted and temporarily jammed in the car ring. He had sailed with me a few times and was a great person to sail with, before he moved away. The pole is always set with the jaws opening down now. We use trigger lock ends and attaching to the mast and "new" guy is not a poblem. In very light air, I would think either way is functionally not a problem, but jaw opening down would work best for me. Jaw opening up and I would probably get confused. I have a 30'' ULDB with an 800 sq. foot masthead spinnaker. This sail is not very forgiving and demands good handling, but, oh, how we love to plane.
Old 03-18-2002
OOOPS! Substitute "up" for "down" in all cases last post by me. A "U" looking from the side, not an upside down U as it came out.
Display Modes
vB code is On
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
