02-03-2007
Sorry to fail, but the discussion was about the RRS sequence which most clubs use, not any local or special sailing instructions.. The answer "prep" signal is always correct, since local rules cannot change that signal.
Also suggest you get in the habit of timing ONLY from your own prep signal, since the RRS allows for discontinuous signals between classes. That is, the signals do not have to start every five minutes (or ten). You will be over early !
