05-13-2007
Checkstays are used to "check" mast bend. Powerful hydraulic backstay adjusters, while they are trying to increase headstay tension, can put a huge compression load on the mast. Un"checked", this action can actually lower the entire rig, slacking off shrouds rather than tension the headstay. (Picture squeezing the ends of a toothpick between your thumb and forefinger)
Some checks are a single line going up about 2/3 the mast height, others split into 2 or more parts, with the parts individually adjustable in some cases.
Check stays are adjusted to limit mast bend, keep the mast in column and transfer the load to the headstay. Overtightening checkstays can actually invert the mast curve, created a very full main when you least need it.
