Go Back   SailNet Community > General Interest Forums > Racing
  #21
Old 08-06-2008
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
Thanks chuck, it was nighmare trying to work out all the logistics.
  #22
Old 08-06-2008
Sabreman's Avatar
Sabreman will become famous soon enough
Mitch - To answer your questions, I'll refer to the rules. Basically, 50.2 says that a spin or whisker pole mast be attached to the mast. The outrigger section (50.3(b) and 50.3(c)) basically define a pole.
The length of the pole is set by the J dimension. If it's greater than J, then it's a spin pole. When I received my rating, I deduced this by inference since I was claiming a non-spin pole credit and to get the credit, the whisker pole had to be less than the J. Hence, I deduced that a spin pole is J or greater.
Since the other boat was using a boat hook that was about 6'-8' long and held by a person, not attached to the mast (neither the pole nor the person), they were in violation of 50.2. I don't see anything about a person standing forward or aft of the mast, but if it's in the rules somewhere, I'll stand (or sit) corrected!
50.2 Spinnaker Poles; Whisker Poles
Only one spinnaker pole or whisker pole shall be used at a time except
when gybing. When in use, it shall be attached to the foremost mast.
50.3 Use of Outriggers
(a) No sail shall be sheeted over or through an outrigger, except as
permitted in rule 50.3(b) or 50.3(c). An outrigger is any fitting
or other device so placed that it could exert outward pressure on
a sheet or sail at a point from which, with the boat upright, a
vertical line would fall outside the hull or deck planking. For the
purpose of this rule, bulwarks, rails and rubbing strakes are not
part of the hull or deck planking and the following are not out-
riggers: a bowsprit used to secure the tack of a working sail, a
bumkin used to sheet the boom of a working sail, or a boom of a
boomed headsail that requires no adjustment when tacking.
(b) Any sail may be sheeted to or led above a boom that is regularly
used for a working sail and is permanently attached to the mast
from which the head of the working sail is set.
(c) A headsail may be sheeted or attached at its clew to a spinnaker
pole or whisker pole, provided that a spinnaker is not set.
Sabre 38 "Victoria"
You may post attachments
You may edit your posts
Which Island Packet? conchcruzer Boat Review and Purchase Forum 40 03-10-2006 05:14 PM
The Worrell 1000—Coming to a Town near You Zack Leonard Racing Articles 0 05-07-2000 08:00 PM
SEO by vBSEO 3.6.1
