Go Back   SailNet Community > General Interest Forums > Racing
Old 09-10-2002
chris1f is on a distinguished road
genoa socks
Does anyone out there use a genoa sock for UV protection? How pleased are you with how it works?
Thanks.
Old 01-03-2003
GeneHale is on a distinguished road
genoa socks
We have an Evelyn 32-2 and race her shorthanded. We were also concerned when just my wife and I sail alone.
We installed a roller furling system and only had to cut a small piece off the bottom of the 155 genoa. We race PHRF here. All of our sails are kevlar or mylar so protecting the sail was important. My local sailmaker made one with a zipper and snaps on each end of the sock. We have maroon/burgundy trim so the sock matches the other things on the boat. You can use a halyard or topping lift to hoist the sock. So all we have to do is furl the sail and then start the zipper from the bottom and someone hoists the sock about an arms length. Goes real fast. And the cost is reasonable. Hope this helps.
Old 01-03-2003
Jeff_H's Avatar
Super Moderator
genoa socks
The big problem that I have with the sock is that it violently rattles the whole rig when the wind pipes up. I have a short length of line that I hook to the zipper and bow pulpit that pulls the zipper closed as the sail is hoisted so that I can put the cover on single-handed.
Old 01-10-2003
tedlong is on a distinguished road
genoa socks
I just bought a new pentex head sail. The sail maker recommended to not use a sock because in high winds the sunbrella will chafe and scratch you nice slick mylar. Also I dont leave my up cause I ruined a mylar sail when moister worked its way in between the laminates and meldewed.
ted
Old 01-10-2003
geohan is on a distinguished road
genoa socks
Jeff: Have you tried a spiral wrap down the length of the sock with the tail of the halyard used to hoist it? Is the sock a great advantage over a sewn-on UV strip along the leach and the foot? I have had no problem with such an arrangement over the last 5 years. I tend to think of it as additional leach and foot reinforcement but maybe I''m missing something. Cheers, George
Old 01-12-2003
Jeff_H's Avatar
Super Moderator
genoa socks
My jib sock has lace lines that do the same thing as a halyard wrapped diagonally. I have used stitched on sunscreens. Besides for the obvious weight problem just exactly where you don''t want weight, they also stretch differently than the sail cloth and so really distort the airflow at the leech. In heavy air it is very hard to elimate the serious leech flutter that results from this distorted air flow without a seriously hooke leech.
The other issue is with 14 headsails, 10 of which are jibs, it would be extremely expensive to put sunshades on each of them. ;^)
"Tall Boy" vs. small Genoa owenmccall Seamanship 3 02-16-2005 03:31 PM
upwind Genoa trimming - lighter airs mikehoyt Racing 9 11-25-2004 03:32 AM
Adjustible Genoa Leads, Track & Teflon rick gleason Gear & Maintenance 5 11-28-2002 08:00 AM
When to use genoa or jib bcooper67 Learning to Sail 1 09-16-2002 02:07 PM
Genoa - high tech or traditional? buchner General Discussion (sailing related) 2 03-03-2002 04:18 PM
