Go Back   SailNet Community > General Interest Forums > Racing
Old 05-15-2009
bkw bkw is offline
bkw is on a distinguished road
barber hauler question
can anybody describe or have a picture of how the barber hauler is used to move the jib lead outboard? do you have to have the lead out of the track on a short line?
Old 05-18-2009
paulk's Avatar
paulk is on a distinguished road
A barber-hauler is usually a block with a tail on it. The jibsheet goes through the block before going through its usual jib lead. The tail gets led to a rail or other strong outboard point like an eye, (perhaps through another block and to a winch) and then to a cleat, so it can be adjusted. It's usually easier to adjust the barber-hauler before trimming the sheet but on some headings, some systems have enough muscle to do it after.
Old 05-18-2009
It may even have a block and tackle on the end of the block, rather than just a tail.
Old 05-18-2009
jackdale's Avatar
jackdale will become famous soon enough
Is this what you want?
I use a spinnaker guy with a snap shackle.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 05-19-2009
bkw bkw is offline
ok got it. a lead attached to a line going through a snatch block at the rail and back to the **** pit where it can be adjusted and cleated.
thanks
Old 05-19-2009
davewild is on a distinguished road
jib trim
Just as a suggestion, I would think you would use barber haulers on a headsail when off the breeze. An old friend at my local yacht club sometimes uses his spinnaker pole set to leeward to good effect. I've not tried it myself but he is a pretty clever yachtie(he was on Southern Cross in the '74 Americas Cup). He uses this if to tight for a spinnaker or if short handed. All it would take to give it a try is a spinnaker pole and a snoter ring to clip it to. Might be worth a try. Let me know what you think/results if you try.
Old 05-19-2009
Of course, barberhaulers make a lot more sense on a multihull, where you really have the beam to make good use of them... going downwind...
Old 05-19-2009
jackdale's Avatar
I assume that the spin is mounted athwartships.
Old 05-19-2009
paulk's Avatar
When to use
Originally Posted by davewild View Post
Just as a suggestion, I would think you would use barber haulers on a headsail when off the breeze. .
That makes sense. It opens up the slot between the main and jib, allowing more air to go through without backwinding the main. You might also want to use them upwind in heavier air, if the main is getting too much backwind and you don't have a smaller jib to switch to right away. Some new boats are being set up without any tracks for jib leads. They use sets of barber-haulers attached to padeyes in the deck to place the clew of the sail wherever they want it - in/out/forward and/or back. It's lighter than a track with cars (and adjusting lines) and probably less expensive too.
Old 05-21-2009
Spinnaker pole is set up as if you were "goose winging" then gybed the main only. Then head up to fill jib/genoa and onto your course. I'm not sure how high you would be able to carry this into the breeze but he swears by it(calls it his turbo-charger). I am guessing but I think height would be dependant on fullness of sail and length of pole.
Keel/ballast Question?? Plus Extra Credit Question ;) stephenronning General Discussion (sailing related) 2 03-20-2009 07:25 AM
Another 12v power question TonyInNewportOregon Living Aboard 3 02-17-2009 10:04 AM
Barber haulers, rigging question zz4gta Gear & Maintenance 13 11-02-2008 03:54 PM
Motor: DIY or Pay up; that is the question canoeman256 General Discussion (sailing related) 11 10-11-2008 05:16 PM
Ladder question mcain Gear & Maintenance 14 08-03-2007 10:28 PM
