Go Back   SailNet Community > General Interest Forums > Racing
  #21 (permalink)
Old 06-05-2009
tommays's Avatar
It is chicken and egg
It depends on the GPS as the new ones do it different and dont require a costly system
The S10 calculates the heading from the downwind reference point to the upwind reference point. This heading is assumed to be the wind direction. Since the only information derived from the reference points is this heading, the position of the reference points in absolute terms does not matter. The only thing that matters is the position of the upwind point relative to the position of the downwind point.
The S10 takes GPS readings every second to get your actual speed as well as the heading of your course. The device then multiplies your speed with the cosine of the angle between your heading and the wind direction to extract the component of your speed that is aligned with the wind direction. This process is repeated every second. Some averaging is then performed to make the output smoother and easier to interpret. The results are displayed on the LCD screen.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #22 (permalink)
Old 06-05-2009
jarcher's Avatar
jarcher is on a distinguished road
And therefor VMG is treated as velocity directly into or directly against the wind. It's merely coincidental that the windward mark happens to be up wind
I suppose this is better than nothing, but wind does shift. I guess if you want to steer to VMG then its better than nothing.
  #23 (permalink)
Old 06-05-2009
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Originally Posted by jarcher View Post
Well VMG to mark vs VMG to the wind are referred to differently in different places. Here is one example:
Why VMG Matters - a knol by John Navas
Ockam and Nexus both use VMG to mean directly into or against the wind, and I have found that this is common when referring to racing.
Several months ago a sailor posted another solution, using a standard GPS: At the start, and as you round each mark, set a waypoint quite a way beyond the next mark (IIRC he suggest a couple thousand miles), on the same bearing as the bearing to the next mark. That way you don't encounter the problem, mentioned in the cited article, of your VMG decreasing as you approach the mark, because you'll never get even close to the far-off waypoint.
Exactly how you go about doing that, I'm not sure. A nice addition to GPS software would be a "VMG on course" (?) display, where the GPS would do this for you. That way you could still display bearing, distance, etc. to the actual mark, but the course VMG would be calculated based on the far-off pseudo-waypoint. Otherwise, I guess you'd need two GPS'.
I found the article I described above: VMG & GPS: VMG USE MADE EASY (“VMG FOR DUMMIES”)
Jim
Last edited by SEMIJim; 06-06-2009 at 10:08 AM. Reason: Added cite for article described
  #24 (permalink)
Old 06-05-2009
SEMIJim's Avatar
Originally Posted by stardvd555 View Post
They'll usually give you a bearing and distance from the previous mark or starting line if its a drop mark course. Check your SI's.
That's not the problem with the GPS method. The problem is figuring out how set a waypoint way off in the distance on that bearing. (I haven't tried it yet, so maybe it's not all that difficult.)
Jim
  #25 (permalink)
Old 06-06-2009
maxmunger is on a distinguished road
The race course is always posted by RC. Either a series of marks or an Olympic course. Either a diagram or a list/map of set marks is provided in the SI's.
Put the waypoints in any little GPS and it will guide you to all of them. With critical boat info including current effect.
  #26 (permalink)
Old 07-23-2009
jaakennuste is on a distinguished road
SailCruiser Pro polar data screen
We always get pre-defined coordinates of each mark. Navigator enters the coordinates into the navigation system. Knowing the wind direction and course, it's possible to calculate target speed, if correct polar data is also entered into the system.
Grand Soleil 42R
My
  #27 (permalink)
Old 07-23-2009
jarcher's Avatar
Cool software, I'll check it out.
In the category of the only stupid question is one not asked? mikeedmo Gear & Maintenance 7 03-30-2007 07:53 AM
Stupid Question #276 thegolux General Discussion (sailing related) 7 02-22-2007 06:37 PM
Stupid engine question sneuman Gear & Maintenance 8 04-24-2003 04:25 PM
A Navigation System for Your Notebook Computer Jim Sexton Gear and Maintenance Articles 0 11-14-1999 07:00 PM
