Go Back   SailNet Community > General Interest Forums > Racing
Old 09-18-2009
stpetersburgsailor
Guest
Posts: n/a
Boat hum
one of my students asked a stellar question regarding boat hum...
why forces of drag vs. positive effect... keel issue
skiff issues... say a 420 or Laser
some say a boat is singin' & in perfect sych when she hums
any thoughts?
Old 09-18-2009
smackdaddy's Avatar
Last Man Standing
Actually, that is a great question. I've heard people talk a lot about it - but know the physics behind it.
BFS Gear: SNers started it....
Old 09-18-2009
St Anna's Avatar
St Anna is on a distinguished road
I can vouch for the hum. Our Peterson sings when when going to windward (probably in at least 20kn apparent) and the sails are well trimmed.
The Peterson designs are a work of art so your question is valid. It has been reported that the 46 with a wider stern has some weather helm in comarison to the 44, but with headsail and main traveller trim, I havent found to much weather helm. Weather helm characteristics, (CE vs CLR & mast rake etc etc) may be worth looking at for the design causatives of 'hum'.
Its a beautiful sound - its just like she is communicating & having fun and its implanted in my memory.
Old 09-18-2009
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
I was on a test sail with Imagine. We were sailing from the Atlantic between St. Maarten, and St. Barts. The spinnaker was up, and as we got on the crest of the wave we got a good gust. We were doing 14 knots, and the boat seemed to dig in, and accelerate quickly. Just as we were peaking at 18 knots there was a small hum. I was in love, and my knees were weak. I was standing there thinking, and SHE'S MINE!........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 09-19-2009
saildork's Avatar
saildork is on a distinguished road
AHHHHHHHHHHhhhhhhhhh!! That special moment when man and boat are as one.
Sailing isn't a matter of life and death. It's much more important than that!
Old 09-29-2009
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
I was under the impression that the hum was caused by imperfections in the bottom and or foils. Fair the bottom, and sand to 600 grit, hum should go away.
Merit 25 # 764 "Audrey"
Old 09-29-2009
philsboat's Avatar
philsboat is on a distinguished road
Boats hum cuz they don't know the words....hehe
Phil
Old 09-29-2009
US27inKS's Avatar
Midwest Puddle Pirate
US27inKS has a spectacular aura about US27inKS has a spectacular aura about
When I was working on my friends keel I ran across a great video showing the cause of keel hum. Unfortunately I can't find it now. Basically it has to do with the width of the rear edge of the keel or rudder. As the foil moves through the water, an eddy forms on the rear edge of the foil. This eddy swirls first from one side then the other. As boat speed increases the eddy switches sides faster and faster until a harmonic vibration is set up in the foil.
The eddy on the back edge of the foil creates drag, and can be eliminated by reducing the trailing edge to a point. This is impractical at best, so reducing it as much as possible is the goal without sacrificing the ability to withstand a small impact. Besides, getting a pointed edge straight is a bitch.
John USYacht 27 "Cora Lee"
Old 09-29-2009
Crapaud is on a distinguished road
In my experience, the hum is a function of speed and exciting the natural frequency of the rudder, keel or combination of the two. My "Fiz-ix" knowledge dealing with fluid flow is rusty at best, but to add to John's comments it is a vibration brought on by flow inconsistencies.
One of my thoughts has been - could this vibration be a result of flow separation (or eddies) coming off the keel that the rudder then contacts and starts the process? Almost like a flag flapping in the wind generated by a fan?
The nat frequency is determined by the object's geometry and stiffness. So, the frequency would be changed by changing the length of the rudder or the materials it is made from. Stopping the eddies completely would probably require NASA to design and build the foils to have no flow separations at the higher cruising speeds.
Old 09-29-2009
stpetersburgsailor
Guest
Posts: n/a
sanding with grit! gee I'm hopin' he was being comedic...
I've sailed BRAND new high performance skiffs & if u took a piece of sandpaper within 20 yards of one the maintenance director would have your head on a platter, a seafood platter
thanks for the foil discussion right above, VERY interesting
& Chapman's discusses this a bit too
cheers
-JD
Making Passage w/o a Rudder wind_magic Seamanship 60 07-16-2010 01:23 PM
Boat Swapping Mark Matthews Cruising Articles 0 07-15-2004 08:00 PM
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 07:00 PM
Fine-Tuning the Autopilot, Part Two Dan Neri Gear and Maintenance Articles 0 10-13-2003 08:00 PM
The Balance of Hull and Sails Steve Colgate Learning to Sail Articles 0 05-25-2000 08:00 PM
