Where to run the halyards - Page 2 - SailNet Community
post #11 of 12 Old 04-21-2010 Thread Starter
jarcher's Avatar
Originally Posted by wunhunglo View Post
BTW: You have a great boat in the Scampi IOR half Ton. One of Peter Norlin's best. Excellent in heavy air. Does yours now have a taller rig than the original design?
Thank you very much. Yes it does, about two feet taller. Why do you ask?
I found this out near the end of last season when I decided to buy some sails and the sail maker came out to measure. He had worked on another Scampi in CT and notided the difference right away.
Last season, I had tremendous trouble keeping the boat flat. The sails were old, so I'm sure that didn't help, but even after the new sails came there was an issue. The sail maker and I suspect it is sue to the extra high rig.
Its very possible it was made this way. The mast step looks to be original, although a new spar could have been made to fit it at some point. I'll probably never know. Even if it was original, I'll never know if the keep was changed to help offset the taller rig.
Helios
Scampi 30 MK-IV
jarcher is offline
post #12 of 12 Old 04-21-2010 Thread Starter
jarcher's Avatar
Originally Posted by zz4gta View Post
Make the spin exit on the starboard side if you normally do port roundings. Keeps the 'jumper' on the high side.
Awesome point, thanks!
Helios
Scampi 30 MK-IV
jarcher is offline
Internal Halyards DWH Gear & Maintenance 9 07-14-2008 06:19 PM
What to Do When You Run Aground Sue & Larry Her Sailnet Articles 0 12-18-2002 07:00 PM
Running Internal Halyards Dan Dickison Gear and Maintenance Articles 0 03-25-2002 07:00 PM
Wire-Rope Halyards Tom Wood Gear and Maintenance Articles 0 08-14-2001 08:00 PM
Samson Pre-spliced Halyards Dan Dickison Gear and Maintenance Articles 0 12-28-2000 07:00 PM
