PHRF questions - Page 3 - SailNet Community
post #21 of 31 Old 08-13-2010
Originally Posted by CalypsoP35 View Post
Nobody has any comments as to whether the above statement is correct?
This was true for us as well. (PNW). Haven't raced NFS, but we do have both the FS and NFS rating on the certificate. No idea about other locales.
puddinlegs is offline
post #22 of 31 Old 08-18-2010
mikehoyt's Avatar
In Nova Scotia we provide a racing and a non spinnaker handicap. The one provison is that you cannot use undeclared sails in any race. Here you must declare your largest headsail, your largest spinnaker and if main is oversized must declare that as well. Sailing with an undeclared spinnaker gives RC no idea if it os oversized, etc... so is not allowed.
Simple answer. Declare the spin and in most reas yo can opt to enter a cruising NFS class or a spin class - you would normally have a slower NFS rating.
Mike
Mike
mikehoyt is offline
post #23 of 31 Old 12-12-2010
If you must change you engine and the closest replacement available changes engine weight from 150 lbs to 250 lbs, how does that change your PHRF?
OPTION is offline
post #24 of 31 Old 12-12-2010
Option, the PHRF ratings are fairly simple.
Your certificate is based on a standard production boat. When you apply for a certificate you are supposed to let your local committee know about ALL custom or variant equipment on the boat. And when you change equipment, you are supposed to notify the committee again, and ask for a re-rating.
They may change your rating based on the added weight, or they may dimiss it as negligible. They may decide your boat is faster because if has more "ballast", or they may decide you are slower because the boat is heavier. Or they may tell you to keep racing for another season and they'll adjust it after they see what difference it makes.
You may want to see what difference the engine makes and then say something about it, when you notify the committee.
If someone were to inspect your boat and find the equipment materially differed from what was on your certificate, you could be DSQ'd from a race, or a season.
hellosailor is offline
post #25 of 31 Old 12-13-2010
I don't discuss my member
zz4gta's Avatar
Talk to your local PHRF official. They can probably give you an idea of the change over the phone before you reapply for a new cert.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #26 of 31 Old 12-13-2010
I would report the change, but most likely there
will be no rating adjustment. PHRF committees are
quick to give a penalty for any modification that may
make the boat faster, but rarely give a 'credit' for
something that may make it slower.
I converted from an inboard to an outboard motor
and recieved a -6 sec/mi adjustment.
Islander 30 II 'COOL'
COOL is offline
post #27 of 31 Old 12-13-2010
Phrf for the new beneteau first 40
Does anyone know the phrf rating for the 2011 beneteau first 40 ?
and for the first 50 ?
cartagena is offline
post #28 of 31 Old 12-13-2010
33 in So. Cal
COOL is offline
post #29 of 31 Old 12-13-2010
PHRF for beneteau first 50
does anyone know the phrf for the beneteau first 50
post #30 of 31 Old 12-13-2010
blt2ski's Avatar
http://offshore.ussailing.org/Assets...+Handicaps.pdf
There is a link to the US Sailings list of phrf ratings for boat, high, low and ave for ALL ussailing reporting clubs etc. So the list may not be accurate per say for your region, but will get you close if there are a few boats like you want rated.
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
Cat 22 rigging questions radioguy Gear & Maintenance 5 08-08-2010 12:35 PM
Charts not chartering questions Diamondjet Chartering 6 07-30-2010 10:39 AM
Lots of questions in death of experienced sailor tyztoy General Discussion (sailing related) 10 07-28-2010 09:32 PM
