06-09-2003
how can I.....
You have added some details that make it easier to understand the situation you describe. Both boats are on starboard tack, approaching the reaching mark, which is to be left to starboard. The other boat is to windward of you, but is overlapped at the 2 boat-length circle, and calls for room. To avoid this situation or at least improve it, you can do two things. The first might be to head off at or near the two boat length circle, in order to break the overlap. This may require taking the windward boat up well before the 2bl circle, so that you don''t have to head so far down to break the overlap that you''re sailing away from the mark. You may be limited in how you take him up, depending upon how the overlap was established> (...if it was within two boatlengths to leeward of him or not- check the rules.) If you can make the both of you approach the mark from the correct angle, your competititor will have no overlap, and you will not have to give them room. The second, trickier, option would be to give the windward boat all the room they want, but to slow down and cut inside them at the mark at the rounding. Since they''re going so wide, there must be room for you on the inside. This requires excellent boathandling and timing skills. The situation and conditions will determine which method may work the best. The third option is to talk to the race committee about avoiding starboard roundings. Good luck!
