04-27-2011
Late to the Party, But my 2 cents
FWIW,
I do the MH Wed Night Race Series as Crew on a J105 and some other boats. I don't race my boat my own boat. My ride is a Pearson 10M, which is very similar to your boat as far as performance.
The bottom line is, that unless you put up a kite, which by the rules you can't, your boat is going to be slow down wind. Putting a 155 instead 135 isn't really going to make a significant difference unless you can pole it out, have the wind to fill it, and fly wing-and-wing. Even then your looking only at a small improvement. Strong winds will not really make a 155 better than a 135 as the boat can only gos fast as it's hull speed will dictate. Putting more cloth up isn't adding to speed. The only time a 155 will help is in very light winds, and typically the MH race committee will call the race if the winds are very light or non-existent. They actually have called races in the middle of a race because the wind is dying down and they want to get home in time for beer. We have been 200 yds from the finish, and moving, and they have called the abandoned/called the race, but it was getting "late"
However the issue with using a 155 upwind is more dramatic. A 155 is going to be harder to trim, tack, and will back wind your main. If your in the race and the wind pipes up, you better have a lot of bodies on the rail to even have a chance of minimizing weather helm or you will need to constantly trim the main/155 to get the boat to sail well. Remember your boat sails fastest at about a 20 deg heal, not like a Bristol 35, where like a 30 deg heal maximizes the wetted surface.
In my opinion, for your boat, if your in the 4-8 kt apparent, a 155 is probably ok, but as soon as the wind is more than 8-10 kt apparent, the 135 is a better choice. We have a 135 and a 150 and I have yet to fly the 150 on our boat.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
