04-11-2011
I can see where you are going with this. One thing to keep in mind.....if your area is LIKE my area, a deck sweeper may still have a bit more SA potential. If you are using 135% of the fro triangle as used here where I am, then the deck sweeper may be better. Another option, is to have a deck sweeper out of lighter better cloth than the HCC(high cut clew) 135 you have now, or splurge for a laminate to race with, save the HCC for daysails and cruising. Also, look to see if you can go to say a 140 or 142 potentially and still keep the 9 sec credit you have. IIRC here in Puget sound a 130-142 is a code 4 as you seem to be describing. So you may be able to go slightly bigger than what you have, keep the rating, gain some speed up and down wind with a larger genoa. Talk to your clubs rating person or whom ever did the rating for you, to see if you can go bigger and not take the hit. If you are going to have a new sail made, max it out for the code size you are trying to stay with in.
Marty
She drives me boat,
I drives me dinghy!
