Polar Diagrams - Page 2 - SailNet Community
 1Likes
post #11 of 19 Old 04-15-2012
Re: Polar Diagrams-Newport41-Benetaeu 421
Newport41
TWA 6 8 10 12 14 16 20
52 5.0 5.9 6.4 6.6 6.7 6.8 6.9
60 5.3 6.3 6.7 6.9 7.0 7.1 7.2
75 5.7 6.5 6.9 7.2 7.4 7.5 7.6
90 5.9 6.7 7.1 7.3 7.4 7.6 7.9
110 5.8 6.7 7.1 7.5 7.7 7.9 8.2
120 5.5 6.5 7.0 7.4 7.7 8.0 8.5
135 4.8 6.0 6.7 7.1 7.5 7.9 8.5
150 4.0 5.1 6.0 6.6 7.1 7.4 8.1
Benetaeu 421
52 5.5 6.4 6.9 7.1 7.3 7.4 7.4
60 5.9 6.8 7.2 7.4 7.5 7.6 7.7
75 6.2 7.1 7.5 7.7 7.9 8.0 8.2
90 6.3 7.2 7.6 7.8 8.1 8.3 8.5
110 6.2 7.1 7.7 8.0 8.3 8.5 8.8
120 5.8 6.9 7.5 8.0 8.3 8.6 9.1
135 5.0 6.3 7.1 7.6 8.1 8.5 9.1
150 4.2 5.3 6.3 7.0 7.5 8.0 8.7
georgesoilis is offline
post #12 of 19 Old 04-15-2012
JordanH's Avatar
Re: Polar Diagrams
I've been curious about my Contessa 26... I wonder if anyone has bothered to create a polar for them.
JordanH is offline
post #13 of 19 Old 04-20-2012
Re: Polar Diagrams
Most interesting.
Polar Diagrams used to be published with every sailboat review in the old issues of Yachting, Rudder and the like. You do not see them anymore. I wonder why. Perhaps the fact that they START at 52 degrees from the true wind angle is a clue.
As a point of reference, my IOD, designed in 1938, and horribly slow, inefficient, and otherwise unsuitable by modern standards, sailed at an average of 39 degrees to the true wind as measured by the course over the ground between known landmarks on the shore of a relatively narrow channel (The Alameda Estuary, Oakland California.) This was before gps, so some experimental error is in there but this is an average of about a dozen runs up the same channel, roughly six legs, dead to windward usually, and it is taken from courses plotted on a chart, by reference to shore marks at each tack. And we were not pinching or trying to prove point. I only did the measurements after the fact when a question like this came up. We were just sailing.
I suppose if I were the NA of a thing that couldn't go much closer to the wind than 50, or even 45 degrees, I would not want the curves published either.
keforion is offline
post #14 of 19 Old 06-27-2012
Re: Polar Diagrams
Originally Posted by Grendler View Post
Diagrams are from 33ft (Pearson, Contessa) up to 60ft (Centurion, Deerfoot, Swan). Sorry
Catalina I got only 36 model:
52 4.9 5.8 6.3 6.6 6.8 6.9 7.0
60 5.3 6.2 6.7 6.9 7.1 7.2 7.3
75 5.6 6.5 6.9 7.3 7.5 7.6 7.7
90 5.7 6.7 7.1 7.4 7.6 7.8 8.1
110 5.6 6.6 7.1 7.5 7.8 8.1 8.4
120 5.3 6.4 7.0 7.4 7.8 8.1 8.6
135 4.7 5.8 6.6 7.1 7.5 7.9 8.5
150 3.9 4.9 5.8 6.6 7.0 7.5 8.2
Thanks but these seem hoplessly optimistic for my TR, WK C36 with newish <4 y.o. dacron sails. I can only comment on the upwind to beam reach figures, since I believe these polars assume a spinniker once past a beam reach and my boat is not set up with spin gear.
Also, Since the wind angle is given as true, I'm assuming the wind speeds are also supposed to be true. Any idea if that's a valid assumption?
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
post #15 of 19 Old 06-27-2012
JordanH's Avatar
Re: Polar Diagrams
PalmettoSailor, you are correct. They are true wind speed and direction.
I came across this PDF that explains it better than I can.
http://www.ockam.com/docs/SplainPolars.pdf
JordanH is offline
post #16 of 19 Old 08-17-2012
Re: Polar Diagrams
Grendler....you wouldn't happen to have Polars for a 1982 Pearson 37R would you?
Thanks in any case.
Greg
greggus2003 is offline
post #17 of 19 Old 08-21-2012
paulk's Avatar
Re: Polar Diagrams
US Sailing has polars for just about anything with sails that floats, but they're not free or cheap. I believe their diagrams show angles of attack from closer to 0 degrees to 180. You can also create your own diagrams empirically, but it's a lot of work to document all the wind speeds, angles, and boat speeds.
paulk is offline
post #18 of 19 Old 03-16-2013
Re: Polar Diagrams
Does someone have the polars available from a gib'sea 444 or 442?
Vanpupi is offline
post #19 of 19 Old 05-27-2014
Send a message via Skype™ to mickmoore
Re: Polar Diagrams
Hello,
I am looking for a Polar Diagram for a Ranger 37...
Would you happen to have one?
Best, Mick Moore
San Diego
mickmoore is offline
Question on Polar Diagrams Ilenart Sailboat Design and Construction 6 04-15-2012 01:04 PM
Cal 30 Polar Diagrams? WinterRiver Cal 5 04-15-2012 12:59 PM
Electrical wiring Diagrams yelnats69 Gear & Maintenance 5 10-01-2009 11:52 AM
wiring diagrams for catalina30 marinoinPV Gear & Maintenance 6 11-17-2007 08:42 AM
Racing Diagrams zeniam1 Racing 0 06-24-2002 08:48 PM
