Fixed vs folding prop - Page 2 - SailNet Community
 2Likes
post #11 of 21 Old 04-08-2012
chrism33's Avatar
Re: Fixed vs folding prop
Slightly off topic.
When sailing, I been told to always keep the stopped engine in gear (forward or reverese) so the prop folds back quickly.
This doesn't seem right to me.
Has anyone else heard this?
ChrisO
chrism33 is offline
post #12 of 21 Old 04-09-2012
First String
My 1981 C&C 30 MK1 manual says 6.7 kt at 3400 rpms.
Well here is the thing the last owner put a folding prop on because he raced. I here a thud when I engage the prop. It donít back up very good. And I can only get around 2,000 rpms? If I push past that very long it starts wanting to smoke black smoke? Like ,I may be pushing too hard on the engine. any advice?
[IMG]Photobucket[/IMG]
ltgoshen is offline
post #13 of 21 Old 04-09-2012
Originally Posted by chrism33 View Post
Slightly off topic.
Check your transmission manual.. most do say to put in reverse while sailing, some do not, incl Yanmar, and suggest you leave it in neutral. Hurth says not to let the prop freewheel while in forward gear..
Either way, stopping the shaft will promote faster folding.. sometimes an unfolded prop will continue to spin otherwise... same with feathering. If your transmission advises against leaving the gear in reverse, you can always just do it long enough to promote folding and then leave it in neutral afterwards.
Sounds like you're overpitched.. a prop shop may be able to fix that for you and repitch your existing prop. btw that style of prop can sometimes only spin one blade open, causing a lot of vibration. If you find that happening get into the habit of giving things a quick spin in reverse prior to shifting to fwd.. seems to help. This mostly occurs when the prop comes to rest with the blades on a vertical axis, and one blade drops open due to gravity and lack of boat speed. The other blade, sitting in line with the shaft sometimes won't flip open leaving you with effectively a one blade prop - a very unbalanced circumstance!
The poor reverse performance is one of the costs of the reduced drag.. if you're not racing and want to avoid all this the Campbell Sailor prop is a good, relatively inexpensive option.
ltgoshen likes this.
Faster is offline
post #14 of 21 Old 04-09-2012
ASA and PSIA Instructor
The opening thud is a characteristic of the folding prop. So is the poor reverse performance.
Another thing to check in terms of cruising RPMs is whether the tach is accurate. In-accurate tachs are pretty common, being off by a lot is not unusual. See
diesel rpm
sailingfool is offline
post #15 of 21 Old 05-23-2012
SchockT's Avatar
Well here is the thing the last owner put a folding prop on because he raced. I here a thud when I engage the prop. It don’t back up very good. And I can only get around 2,000 rpms? If I push past that very long it starts wanting to smoke black smoke? Like ,I may be pushing too hard on the engine. any advice?
It looks like you have a Martec prop, which is the worst of the folders. I had one of those on my boat, until I found a good deal on a used Gori prop, which is the same idea except there are gears so the blades open and close together. It is definitely smoother, and reverse is much improved; still not great, but better than the Martec. It definitely sounds like the prop isn't sized correctly for your engine.
SchockT is offline
post #16 of 21 Old 05-23-2012
Send a message via Yahoo to dacap06
SchockT,
Low RPM in gear and black smoke at speed? This description is the classic one for a prop that has too much bite for the motor driving it.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #17 of 21 Old 05-23-2012
SchockT's Avatar
Originally Posted by dacap06 View Post
SchockT,
ergo the prop is not sized correctly (I guess I should have said "matched"?)
Whether the diameter is to big or the pitch is too great, the symptoms will be the same will they not?
Sheesh! A guy sure has to choose his words carefully on this site! :-)
SchockT is offline
post #18 of 21 Old 05-24-2012
Even for cruising there is no question that a folding or feathering prop is a massive increase in speed while sailing. Probably the single best thing you can do to increase the performance of a boat.
Yachting Monthly did a really nice right up of a number of different folding/feathering props, and what they found was pretty surprising.
1) the drag from a fixed prop is roughly the same as HALF the drag from the entire rest of the boat.
2) backing characteristics of the good folding/feathering props was actually better than that for a fixed three bladed prop
3) feathering/folding props has less prop walk than a fixed generally
4) forward thrust from the feathering/folding props was within 5% of a fixed prop.
Based on this study I actually just replaced my fixed with an auto stream, and couldn't be happier. I wanted the flex-o-fold but couldn't find a US distributor. The results have been exacally what I expected. Similar forward speed and control, much better control in revers with less prop walk, and greatly increased speed while sailing.
A reprint of the study http://www.flexofold.com/upload_dir/...onthly_low.pdf
Stumble is offline
post #19 of 21 Old 02-06-2015
I'm on my 4th boat. This is the first one with a fixed prop. 2 blade. It's by far the slowest under power of any of my boats. (all yamaha all 30 or 31 feet)
The boat moves under sail like it was coated in Vaseline so I can't gauge how the fixed props slows me down.
I do catch a lot of seaweed under sail in seaweed season of spring (I sail Taiwan and the southern Japan islands) Good thing is that you don't need a waterproof lamp at night because the phosphorescence with every strike of the knife lights everything up.
Chris.Carney is offline
post #20 of 21 Old 02-06-2015
ltgoshen, you may have a 1to1 transmission and not a 2to1.
I suggest you go to the Moyer Marine forum to get the proper pitch numbers for C&C Mark1.
There is an active contributor from Halifax, with the same boat.
sony2000 is offline
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 07:52 AM
folding to fixed prop Gulfislander Gear & Maintenance 8 08-03-2010 07:49 PM
Fixed vs Folding Prop doons60 Gear & Maintenance 11 07-29-2007 08:27 PM
Fixed vs. Folding Props: How Much Difference? SEMIJim General Discussion (sailing related) 16 07-15-2007 01:51 PM
Inboard fixed vs. folding prop & ratings mikehoyt Racing 6 06-06-2004 10:07 PM
