Fixed vs folding prop - SailNet Community
 2Likes
post #1 of 21 Old 03-25-2012 Thread Starter
Any guess as to the speed advantage of a 37' boat with a saildrive fixed vs folding prop. The fixed blades have a surface area of 35-38".(each blade is 7" x 3" +/-) What do you think, reaching 12 knots of wind... Fixed is 6.7knots on the polars.
Greyhound37 is offline
post #2 of 21 Old 03-25-2012
Junior member, rest old
msmith10's Avatar
Re: Fixed vs folding prop
Not a simple question and as far as I know there's no simple answer or formula. Folding prop will be faster, that's about all you can say. 2-blade, 3-blade? Wind speed?
At hull speed it won't make any difference. In light air it will. If you spend most of your time racing, you'll want the folder, but then again if you race a lot you probably have one already. If you race occasionally but have to motor 3 miles up a river against 4 knot current to get back home, you may just decide to eat the speed loss. If you'd prefer to motor than sail when the weather gets rough, go with the fixed blade.
If I recall, PHRF gives you 8 seconds per mile for a 2 blade folder over fixed, 12 seconds for a 3 blade. It will cost you more than that, otherwise every racer would have a fixed prop.
If I had the money for a saildrive, though, I'd definitely spring for a feathering prop (slightly more drag than folding but better performance).
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 21 Old 03-25-2012
ASA and PSIA Instructor
Half a knot.
msmith10 likes this.
sailingfool is offline
post #4 of 21 Old 03-25-2012
msmith10's Avatar
I was wrong. There is a simple answer, as good as any.
Mark Smith
msmith10 is offline
post #5 of 21 Old 03-25-2012 Thread Starter
8 seconds per mile or .5 knot, either way that is plenty. I was trying to decide if i want to replace the fixed prop now and guess i better.
post #6 of 21 Old 03-25-2012
msmith10's Avatar
After replacing my 2 blade fixed with a folder several years ago, I went from 2nd-3rd place finishes to consistent 1st-2nd place in our club races. The folder doesn't back well, and it doesn't drive well in a chop, but I'd rather sail with rough seas anyway. It was worth the sacrificed performance under motor.
Mark Smith
msmith10 is offline
post #7 of 21 Old 03-25-2012 Thread Starter
Wow that is impressive. The Flexofold has cruising folding blades or racing using the same hub. I noticed that is the prop on several boats hauled near my boat Mumm 36, J-111
After spray applying VC offshore, would not be practical to be dragging a bucket under the boat. I hope to do 4 races this year but mostly cruise (as fast as i can go)
Thanks for the input!
post #8 of 21 Old 03-25-2012
We recently switched from a 2 blade fixed to a 3 blade Max prop.. the difference is remarkable and percentage wise much higher in the light air 3-4 knot boatspeed range than the powered up 5-6+ knot range. We probably reach our optimum upwind speed now in 5 knots less wind than before, and can ghost along at 3-4 knots where 2-3 would have been it before.
The feathering props do away with the folders' reverse issues, and 3 blades is much less vibration under power too... but at a cost, of course ($$$)
Faster is offline
post #9 of 21 Old 03-25-2012
Simple answer of 1/2 knot seems about my experience with my
Flex o Fold, but as stated above by Faster equal advantage is
sailing in light conditions.
Have cruising blades attached to saildrive very good forward speed
and no apologies for reverse, can and have stopped on a dime.
If you go flex-o-fold make sure you or your installer, properly
installs "tab washer" (simple but important).
Also I used red loctite on my install, I will have to heat things up to remove, but hopefully will not be telling any stories about the
time I lost my $1000+ prop in the middle of nowhere.
HUGOSALT is offline
post #10 of 21 Old 03-27-2012
blt2ski's Avatar
If racing, the credit of 9 or 15 secs locally for a 2 vs a 3 blade prop is NOT any advantage, you lose more than that, and gain way more speed with a folding/fixed prop than the credit is worth. .5-.75 additional speed seems to be the norm in speed gain. As faster said, you hit X knots in less wind etc etc.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 07:52 AM
folding to fixed prop Gulfislander Gear & Maintenance 8 08-03-2010 07:49 PM
Fixed vs Folding Prop doons60 Gear & Maintenance 11 07-29-2007 08:27 PM
Fixed vs. Folding Props: How Much Difference? SEMIJim General Discussion (sailing related) 16 07-15-2007 01:51 PM
Inboard fixed vs. folding prop & ratings mikehoyt Racing 6 06-06-2004 10:07 PM
