- Quick Menu
11Likes
05-27-2012
Reefing while racing
How would you set a reef while racing? I tend to race short handed, so I don't have a lot of rail meat to balance the boat. In the past I have been in races where the winds started at 8 to 10 and ended more like 18 to 22. My boat sails better standing up so I would have liked to put a reef in but did not want to head up and lose time and position. So we just manhandled the rudder against the weather helm and rode the boat on its side. I have recently moved my main and reef lines to the cockpit. So it may be possible (I have not tried it) to pull the main down with the tack reef line, while it is still powered. Should I let the main out to de-power it and then reef? Most of the races I have been in are around 3 sides once or twice rather than point to point.
I am new to racing and mostly just daysail, so reefing early is what I do when out alone.
thanks,
Re: Reefing while racing
This is relevant to my interests!
Last week, I was leaving the local bay heading into LI Sound on a beam reach on a port tack when the wind picked up to the point that I was heeling beyond what I felt was comfortable. However, I did not want to risk running up on the lee shore to my starboard side should I run into any problems reefing. I was also single handed that day. So I simply let out the main and sailed far enough along, still practically exceeding hull speed, to a point where I felt safe enough to head into the wind and reef properly.
The downside to this tactic was that although I was not racing, I was passed by 2 other boats as my main flapped noisily in the wind.
05-28-2012
Why would you head up to reef? Luff the main and reef. Your foresail with drive the boat. A rudder hard over, fighting weather helm, is called a brake.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
05-28-2012
Originally Posted by jackdale
Why would you head up to reef? Luff the main and reef. Your foresail with drive the boat. A rudder hard over, fighting weather helm, is called brake.
Exactly... leave the headsail trimmed for close hauled, hold the course, ease the sheet and vang and let the helmsman carry on while the reef is put in, then trim and off you go, more comfortable and likely faster to boot.
There's often too much 'macho' non reefing action just because it's 'racing'... usually at the expense of actual speed.
05-28-2012
Yep. I didn't know there was any other way
05-28-2012
honestly though, we rarely reef in a race. If conditions warrant, sure. Nothing macho, but so long as the bottom 1/2 - 1/3 of the leach is still working, most boats are faster with a full main. For us the crossover is somewhere around 25 kts sailing upwind depending on air temps. Of course racers are working much more actively at sail trim than when cruising, so reefing would happen earlier in cruising mode.
05-28-2012
Well, for one thing, when I am single handed, relying on the AP or wheel lock to hold her steady in a gust to wrestle with putting a reef in the main and standing on the foredeck is daunting!
05-28-2012
It's not only daunting, it's unrealistic, if you don't have a reliable means of self steering while you're away from the helm. I've been on a sailboat when a full race crew was barely able to get the sails down when she was caught in a sudden microburst. If you had been singlehanding at the time, and had to leave the helm virtually uncontrolled while taking down the sails, I have no doubt that the boat would have gone down, as did a bigger boat in the same storm. Regardless of whether you're singlehanding or fully crewed, and whether you're racing or cruising, you can't allow yourself to get into a situation in which the conditions are beyond your ability to cope with them. When singlehanding, you have to anticipate worsening conditions, and prepare for them while you are still able to do so. It doesn't really matter whether you're racing or cruising.
05-28-2012
I have single-handedly reefed at the mast without it being that daunting; I was tethered. Reef when you think about. If you do not have an AP you can also reef while hove -to. But that is not a good racing strategy.
05-28-2012
I think another reason why reefing is not done racing as soon as cruising is the short legs of round the cans...
| Thread Tools |
Search this Thread |
You may post attachments
You may edit your posts
