Centerboard position - keel/centerboard Tartan 37 upwind - Page 2 - SailNet Community
post #11 of 15 Old 07-02-2012
CalypsoP35's Avatar
Re: Centerboard position - keel/centerboard Tartan 37 upwind
I know this sounds counter intuitive, but I could have sworn that I read an article that stated you need less centerboard in high winds and more in low winds. The reason being that in high winds the boat's greater speed creates more lift. In low wind conditions, you need all the CB you can get because you have less boat speed therefore less lift.
CalypsoP35 is offline
post #12 of 15 Old 07-02-2012
CalypsoP35's Avatar
I just google'd centerboard position and the articles stated the farther forward the boat is the more the boat is forced to head up. So the conclusion was if you are in heavy wind which is creating weather helm, you want less board). If the boat is falling off wind (lee helm) you want more CB.
I'm referring to only upwind sailing here. Off wind the board comes up. I have been able to balance my boat withe CB so that I don't have touch the wheel when I get her balanced.
post #13 of 15 Old 07-02-2012
Neither of those tactics work on my boat. from 0 to 10 knots or so, I can sail to windward nicely without any board down, above 10 knots, I'll begin to lower the board in increments to help reduces weather helm and leeway, and allow me to point higher...I've been playing with just how much..but, halfway feels right between 10 and 15..above 15 I'd probably lower it completely.
Off the wind, the board starts coming up in increments until when downwind there's no board down.
tempest is offline
post #14 of 15 Old 07-02-2012
Thatís been my experience as well.
Also, on a reach in heavier air, we tend to add a little more centerboard to help keep us from slipping sideways, and trim the sails for balance.
Lowering the centerboard in a moderate chop helps stabilize the boat. It stands to reason that if the boat is better stabilized, airflow over the sails will be improved.
I donít think there are any hard and fast rules for centerboard use, just rules of thumb. Your boat will tell you what she needs, you just have to listen to her. But kind of like my wife, knowing exactly what she wants takes some practice and experience.
Tweegs is offline
post #15 of 15 Old 07-02-2012
Tweegs, Yes, I agree that off the wind in heavier air, the board helps slippage and gives a more neutral helm, since she'll fight to head to wind.
tempest is offline
How does a fixed keel boat differ from keel+centerboard? phboujon General Discussion (sailing related) 9 06-11-2009 11:29 PM
pearson 33 centerboard vs.tartan 30 mysticsailor Boat Review and Purchase Forum 8 02-07-2009 03:51 PM
Help - Centerboard or keel extension? vanduynesailer Chesapeake Bay 0 09-22-2006 09:33 PM
Keel/Centerboard thoran Gear & Maintenance 2 08-27-2006 01:38 PM
Centerboard Position Fran49829 Learning to Sail 10 05-06-2002 05:24 PM
