Another new sail question/rant - Page 2 - SailNet Community
 6Likes
post #11 of 21 Old 09-12-2012
overbored's Avatar
Re: Another new sail question/rant
Originally Posted by zz4gta View Post
Laminate sails require more care, which means no "late breaks" when tacking overlapping headsails, flake or roll them, put them away dry, and don't let them sit in the sun when not in use. NEVER furl them. I don't care if it's a "furling" J105 class jib. Furling is bad. The sport boats guys know this, accept it, and just replace the jib on a more frequent basis.
why is furling them a bad thing? if you are referring to sailing with a partially furled sail i would agree. the fact that they are rolled a little tighter then when hand rolled may have an effect on some types of fibers like carbon but my laminate panel sails have held up much better since being furled. can't see how the abuse of sails being handled on the foredeck to be raised and lowered is better for them then keeping them rolled on a furler with a cover over them.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #12 of 21 Old 09-12-2012
DrB
Partial thread Hijack
I often get a kick out of folks that are basically club/weekend racers and spend oodles of $$ new sails every few years and think it makes a huge difference on how they place.
I raced over the winter on a J24 out of a sailing club/school. They had about 15 boats and each week you got assigned a different boat. Some boats had better sails than others. In the end, it came down to the skipper and crew, not the sails. I was fortunate enough to be with a world champion skipper who had more knowledege about the boat and sailing in his thumb than I did in my entire body. Consequently, we won or came in second out of 15 boats almost 45% of the time and I learned more about racing tactics from talking with him and watching what we did over the 4 months of w/e sailing, then I had over the 20 years previous sailing years.
Same with beer can/club racing. If folks want to do well in these races, find competent crew, practice, and become a better helmsman. If you don't want to do that, getting a new Hi Zoot sail isn't going to give you any advantage over the guy/gal in the old boat with the "blown" sails that has competent crew and knows how to eek every microknot of speed from his vessel and has better tactical skills.
DrB
msmith10 likes this.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #13 of 21 Old 09-12-2012
I don't discuss my member
zz4gta's Avatar
Originally Posted by johnnyquest37 View Post
"Sails made from (Kevlar) are very light but far from durable in a cruising context.
Cruising and Kevlar shouldn't even be in the same sentence. That's like taking the Maserati to the corner store to get a gallon of milk. In a "cruising context" Kevlar is a complete waste of money.
Kevlar is brittle and does not stand up well to flogging and flexing"
Yup. When you compare it to polyester, it sucks. Carbon is worse.
Further in the text he states "It's not unusual for a woven sail to last 10 years or more, while the lifespan of a laminate sail is closer to five years," but he's talking Mylar here as opposed to Kelvar.
Couple things here.
1. Woven sails will retain a triangle shape longer than string sails. However, their aerodynamic shape is long gone before the triangle explodes. This was discussed in the other thread. For racing, I want a sail that's going to hold it's shape in a wider wind range for a full 5 years of hard service. Lightweight is a nice plus. Dacron will stretch a lot over a 155% between 6-8 kts and 15 kts true. This is not good on the course. Not only that, but it will gradually stretch out over the next 5 years losing performance every year. Until at the end of 5 years, the laminate is pulling and pointing much better than the dacron. This is huge on the racecourse. Not so much for the cruiser who just wants to close reach around the harbor.
2. Mylar is a scrim that is applied to each side of the sail. The aramid strings/threads are sandwiched between these two layers. Mylar can't carry the load of any decent size sail. Small boats and wind surfers have plain mylar sails w/ no strings, their loads are much much lower.
Racing Laminates - Sailcloth Technology by DIMENSION-POLYANT - Sailcloth and laminates for high performance sailing and polyestersailcloth for surf
Scroll down to Flex line and hover over the cross hairs. A graphic pops up that shows the film (mylar) on either side with the string fibers inside the sandwich. Glue, heat, and preassure keep it all together.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #14 of 21 Old 09-12-2012
Chastened
Ajax_MD's Avatar
ZZgta is one of those guys who can sail a blown-out boat and win. Because he is now a "Skilled Indian", now he invests in "Good Arrows".
Like you say, buying Good Arrows for crappy Indians is what a lot of people do.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #15 of 21 Old 09-13-2012
zz4gta's Avatar
lol, never heard it put that way, but I like it!
Another question I ask owners who have pin stop jib car adjustments.
"if you haven't drilled 2 additional holes between each factory hole on your jib tracks, you don't need laminate sails".
Unfortunately the majority I talk to give me the speach "my sails are 15 years old and are still in great shape!" And they couldn't be more wrong, but have convinced themselves that their boat just "likes more wind" to be competitive. Or they have "too much stuff" onboard, it couldn't possibly be that they aren't good enough, or their sails are junk.
Bubble, check you emailz.
zz4gta is offline
post #16 of 21 Old 09-13-2012 Thread Starter
I think it's easy to make sweeping statements, about the properties of a fiber or method of construction. (I'm guilty of doing the same thing).
My real question is, do we (the performance/racing sailer) need do give up durability to get continuous fibers. And what real advantage is there over horizontal, glued/sewn seams (non-continuous fibers). Is there really that much stretch or 'energy loss'. I certainly don't know the answer.
At the same time, I have to step back and face the fact that those of us who engage in such hair/fiber splitting belong in the loony bin. But it's all in good fun.
Randy Browning
Norwalk, CT USA
sonosail is offline
post #17 of 21 Old 09-13-2012
SchockT's Avatar
Re: Partial thread Hijack
DrB
While what you say might be true in some fleets where there is wide ranging skill levels, I have found that even at the upper range of club racing sail quality is a factor. In any established one design fleet there are different tiers. There is always the same group of boats at the front of the pack. Those boats are usually all pretty equal when it comes to skill level, but you will notice that the other thing they have in common is that they all have good sails. Assuming boat handling and tactics are comparable there is no way a boat with worn out sails is going to win consistently.
SHNOOL likes this.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #18 of 21 Old 09-14-2012
zz4gta's Avatar
A this point, we don't have a choice.
There is an advantage. On my 25 footer, probably not noticable. On an R/P 66 definitely. Bigger boats require things that stretch less. 1% on a laser is a lot less than 1% on a 2:1 halyard on a 60 footer. Most small boats don't need continuous fiber load path sails. But an R/P 66 has more than a few Pro's on board, and they're used to working with good stuff.
zz4gta is offline
post #19 of 21 Old 09-14-2012
SchockT's Avatar
It is not just about stretch. Even a traditional paneled kevlar sail has very low stretch characteristics. The big advantage of the 3DL type sails is the weight savings. Not only do they not have the weight of all the thread and seam allowances, they can also control exactly how many strands of kevlar they use, so they only use as much as needed. Even a few pound of weight savings is significant when you multiply those few pounds buy a 50' mast. One piece laminate sails are MUCH lighter than their paneled equivalents.
Hull#101
SchockT is offline
post #20 of 21 Old 10-17-2016
The glue they use in laminate sails has improved a lot. Sails don't "de-laminate" the way they used to, and thus last much longer. I race heavily and buy laminate sails. I'm just thinking of replacing the #1 genoa that was new in 2009. It's held it's shape just fine, and there is little to no delamination, however it is pretty beat up along the foot and leach where it passes over the life-lines and shrouds. My laminate mailsail is 5 years old and looks and sails like new. My #3 blade is older than any other (2006?) and is still in good shape, though it doesn't get used as much. These sails are in every way better than Dacron, except price.
Loki9 is offline
Dockside Rant Donna_F General Discussion (sailing related) 20 07-28-2011 01:05 PM
Just a rant, nothing more Bilgewater General Discussion (sailing related) 15 07-08-2010 12:22 PM
Need to rant.... PalmettoSailor General Discussion (sailing related) 31 06-06-2008 08:26 AM
Raymarine Rant Quickstep192 Gear & Maintenance 2 03-25-2008 06:00 PM
STINKPOTS! A question... A rant... seaspot General Discussion (sailing related) 30 06-26-2007 07:18 PM
