Go Back   SailNet Community > General Interest Forums > Racing
Old 03-20-2004
dpboatnut is on a distinguished road
Core covering for stripped lines
I''ve spliced up some eyes in 1/8" Endura braid for some light air spin sheets, and I''ve got some Tylaska spool shackles on the way.
Has anybody ever added a cover to one of the small, slick lines or is that strictly a pro rigger''s kind of work?
I can get the cover from some 3/16" StaSet onto the rope, but the trick is to keep it from just sliding off. Any ideas or resources for ideas?
Thanks!
-Chad
Old 03-30-2004
39512's Avatar
39512 is on a distinguished road
Chad,
It can be done but requires the cover to be stitched or seized onto the core. Samson Ropes website shows alternative method of using a double braid line, removing a portion of the cover, burying or tucking the cover, then whipping the "crossover".
I have done this job using different techniques, and machine stitching seems to work the best. 1/8" is pretty small. You might want to find a double braid with a 1/8" core and strip the desired length of cover, then use the Samson technique.
You want to be sure that the core and cover stretch together. The cover can bunch up and jam in a block.
cleaning lines & sheets c25 Gear & Maintenance 16 11-06-2006 07:03 PM
Lines aft - what''s best? raybies Gear & Maintenance 6 01-01-2004 11:27 AM
Hull Core WastinAway Gear & Maintenance 5 05-24-2002 11:20 AM
Safety Lines with Flags?! davidk Seamanship 6 03-24-2002 01:49 PM
creating a loop in braided core line Sloop23_417 Gear & Maintenance 1 08-28-2001 09:34 AM
