Visibility of course marks - SailNet Community
 2Likes
post #1 of 15 Old 04-04-2013 Thread Starter
rhr1956's Avatar
What can we do to make our course marks easier to see?
We lake race and use some marks we made out of 8" PVC pipe about 8 ft long with end caps permanately anchored. They stand about 4 ft above the water. All the marks are white and hard to see.
rhr1956 is offline
post #2 of 15 Old 04-04-2013
Letrappes's Avatar
My club does the same thing. We paint a couple black bands on them to make them stand out from the other small markers and the background. It's not perfect but it helps.
Letrappes is offline
post #3 of 15 Old 04-04-2013
Re: Visibility of course marks
Maybe add a smaller diameter extension with a bright nylon flag.. easy to make.
Faster is online now
post #4 of 15 Old 04-04-2013
chucklesR's Avatar
Our's on the Magothy are yellow.
Yellow is the color that is easiest, and first, seen at a distance.
Black text on Yellow is the easiest to read.
Yellow is also not a normal USCG marking color.
chucklesR is offline
post #5 of 15 Old 04-04-2013
Paint them yellow as chuckles mentioned.
Greg
Stumble is offline
post #6 of 15 Old 04-06-2013
paulk's Avatar
The Coast Guard requires our racing marks to be orange and white, but we're on salt water, not a lake. We use orange and white striped plastic highway construction barrels that we attach (screw down) to a square float. One that's a bit further out than the others has two of them stacked. Each is labeled with a big letter on four sides to identify it. Knowing where to look, we can generally pick them out more than a mile off, without binoculars.
paulk is offline
post #7 of 15 Old 04-06-2013
SchockT's Avatar
We can't have permanent marks, so we have to set marks on race day. We use large yellow or red inflatable marks, and even those can be tough to spot in the distance. White is a terrible colour to spot. Pait the marks orange or yellow, and, as Faster suggests, add a flag.
Of course if it is a permanent mark, then it's position should be known to everyone, and there really isn't any excuse to not have a waypoint for each mark, even if it is just on a smartphone!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #8 of 15 Old 04-06-2013
paulk's Avatar
If you take that one step further, why not just have each boat round each waypoint, and not have physical marks at all? Wouldn't THAT make the TV viewers absolutely nuts at the Olympics?
paulk is offline
post #9 of 15 Old 04-06-2013
SchockT's Avatar
Yeah I can just see the protests on whether or not you were in the 2 boat circle, or if you hit the mark!
Hull#101
SchockT is offline
post #10 of 15 Old 04-07-2013
paulk's Avatar
Couldn't you set the proximity alarm on the GPS so you'd KNOW that you were in the circle? The RC could superimpose the two tracks and KNOW who was doing what. Lots of fun!
paulk is offline
Fender marks... bettyswollocks Gear & Maintenance 12 11-13-2008 12:21 PM
racing marks sailingfool23 Racing 2 08-28-2003 06:12 PM
Sea Level Visibility Dan Dickison Cruising Articles 0 08-02-2002 08:00 PM
Racing Buoys / Marks PaulTV Racing 1 11-16-2001 10:01 AM
