83 Ericson MK III 35.5 6' Draft? Universal Help - SailNet Community
 1Likes
  • 1 Post By mikel1
post #1 of 6 Old 09-29-2013 Thread Starter
Ric35-3's Avatar
Looking at a 83 MK III 35.5 Sweet Lines Glass looks good no Blisters. Universal diesel has not been started in 20 years?? She is on the hard gettin ready to toss her back in !!(= Any help with or Ideas on how to Start a Diesel that has not started in 20 years??? Is ^' Draft to much for a Cruiser??
Rich
Ric35-3 is offline
post #2 of 6 Old 09-29-2013
ScottyG24's Avatar
Assuming it is not seized or the block isnt cracked and theres enough left of the rings to make compression (big asumptions) you need start with the fuel system. remove the fuel tank and clean and or replace,clean out or replace all fuel lines, change all fuel filters,bleed the system completetly. change the engine antifreeze/coolant and rawwater pump impellor,confirm the glow plugs work, change oil and filter and try to crank it up. Personally id say if you really want the boat plan on the cost of replacing/rebuilding the motor in your costs to own it right off the bat.
ScottyG24 is offline
post #3 of 6 Old 10-02-2013
Smile Re: 83 Ericson MK III 35.5 6' Draft? Universal Help
ericsonyachts.org . . . the best resource out there for Ericsons!
JulieMor likes this.
mikel1 is online now
post #4 of 6 Old 10-03-2013
Senior Moment Member
SloopJonB's Avatar
There are several threads on starting old diesels. Scotty has it covered but goes too far IMHO - forget removing the tanks before starting - huge job that may not be needed. Old diesels are amazingly robust and can take being left for a long time.
Put a wrench on the crank and see if it's free.
Replace all the fluids, replace the impellers, belts, filters etc. Check the state of the heat exchanger and exhaust hoses and so forth.
Pump out the fuel tank or have the fuel polished, add some fresh fuel and try to start the engine.
It will almost certainly fire up, if not, commence normal troubleshooting.
SloopJonB is online now
post #5 of 6 Old 10-03-2013
Lightbulb Re: 83 Ericson MK III 35.5 6' Draft? Universal Help
Thanks! And, since that's very likely a Universal M25 diesel, another awesome 'net resource are the Universal diesel forums on the large Catalina 34 web site.
Regards,
Loren
moderator, EricsonYachts.org: The Starting Point on Ericson Yachts!
olson34 is offline
post #6 of 6 Old 10-10-2013
Rich
If I were you, I'd get a discount on the price, big enough to cover most of the cost of a brand new diesel.
The issue is that engine most likely has issues, and even if it doesn't, it's close to functionally obselete due to lack of spare parts availability. A replacement raw water pump now costs close to $400, and going up daily.
MarkSF is offline
draft scottmillington Boat Review and Purchase Forum 22 02-27-2010 12:19 PM
How much draft ? gonesailin40 Boat Review and Purchase Forum 35 10-27-2007 10:57 PM
How Much Draft? Cheetie Cruising & Liveaboard Forum 2 04-28-2002 12:21 AM
How much draft is OK? Cheetie Boat Review and Purchase Forum 2 04-26-2002 12:22 PM
Draft help??? troyaux Boat Review and Purchase Forum 2 03-20-2002 04:41 AM
