Time to resurrect the Ferrocement yacht? - SailNet Community
 12Likes
post #1 of 25 Old 07-14-2015 Thread Starter
boz86's Avatar
Since the 1970s, which seems to have been the heyday of ferrocement yachts for the leisure boat industry, concrete technology has made some significant advances. Specifically, glass fibers and superplasticizers have improved the workability and strength of concrete.
Glass fibers provide more anchor points for the cement, much as rebar does but on a more localized scale. Superplasticizers have been described as the equivalent of a dryer sheet for cement. It breaks the electrostatic bond of cement molecules which lets the concrete spread much more evenly and consistently.
This makes me wonder if it's time to look at the ferrocement yacht again, at least for the DIY boat builder?
First, what is a ferrocement boat? Short version, ferrocement boats are wood (or whatever, I guess) framed boats covered in wire mesh on which a cement mixture is placed. Done right, weight was about the same as a steel boat.
Superplasticizers application could improve ferrocement boat building in three ways: 1, the cement mix spreads much more evenly, leaving less voids for the sea to get in; 2, it increases the compressive strength significantly; 3, it can remove the need for a "steam hut" used to cure the mixture on the boat hull. (Concrete cures stronger when it's water evaporation is slowed while curing.)
New glass fibre technology, although it doesn't add much normal (compressive) strength, does address two of concrete's "weaknesses:" 1, it's normally weak(er) in tension than other materials, and more importantly to our discussion; 2, it's brittle. The glass fibres of today address that and a lower brittleness of a hull could be of high interest to someone with the misfortune to run aground.
sid.ir/en/VEWSSID/J_pdf/103820080504.pdf
How to Build a Boat Out of Ferrocement - DIY - MOTHER EARTH NEWS
Mr. Bubs likes this.
"The Stone Age did not come to an end because we ran out of stone." Sheikh Yamani
boz86 is offline
post #2 of 25 Old 07-14-2015
Closet Powerboater
MedSailor's Avatar
Re: Time to resurrect the Ferrocement yacht?
Interesting.
Since the target market is the home builder, how difficult are these new techniques to implement? How about inspection and QC?
I salute anyone who actually completes a home boat build of any kind. I built a 14ft boat out of Bolger's "Instant boats" and it took much more time (and money) than I expected. I can't even imagine a real backyard build.
MedSailor
MedSailor is offline
post #3 of 25 Old 07-14-2015
S/V Calypso
clip68's Avatar
Let us not forget the advances being made in self healing concrete. Having a material for a boat hull that heals itself would definitely raise it above those current construction materials.
The average man will bristle if you say his father was dishonest, but he will brag a little if he discovers that his great-grandfather was a pirate. – Bern Williams
clip68 is offline
post #4 of 25 Old 07-14-2015
Bristol 45.5 - AiniA
It may be that ferro-cement boats now make more sense than in the past, but the problem with any home-build is the total cost. You can get such good bargains on the used market that building your own makes little or no sense financially.
miatapaul likes this.
After the refit we have decided to sell Ainia. We want something smaller that would be could for the light summer winds of Lake Ontario, although we plan to spend at least a couple of winters in the Caribbean before heading north.
killarney_sailor is online now
post #5 of 25 Old 07-14-2015
Daniel - Norsea 27
Rhapsody-NS27's Avatar
a boat is hardly a wise financial decision.
It's still not going to stop anyone from building wooden boats, bare hulls, restorations, etc.
MedSailor likes this.
Daniel
1981 Nor'sea 27,
“Who is staring at the sea is already sailing a little.”
-Paul Carvel
Rhapsody-NS27 is offline
post #6 of 25 Old 07-14-2015
AdamLein's Avatar
Bah, whatever. If boats make you happy, then it's wise to spend money on them, and wise to consider various approaches to acquiring them.
MedSailor and Rhapsody-NS27 like this.
s/v Laelia - 1978 Pearson 365 ketch
AdamLein is offline
post #7 of 25 Old 07-14-2015
Chastened
Ajax_MD's Avatar
While it's true that boats rarely yield a monetary return on investment, they pay back in massive quantities of "utility".
Utility Definition | Investopedia
Rhapsody-NS27 likes this.
1981 Tartan 33 #168
Ajax_MD is offline
post #8 of 25 Old 07-14-2015 Thread Starter
boz86's Avatar
I don't think the materials would be any more difficult to use than the original in most ways. The "pourability" of the concrete mix is easier with the plasticizer and the builder would just need to measure carefully and mix thoroughly.
There is one thing I've not quite worked out in my head. As the pourabilty goes up I'm not sure how well it would stick to the upside down hull and in the mess. This stuff flows really well. Which is good in that the need to vibrate goes way down as do the voids. But it won't do much good if it runs off onto the ground.
boz86 is offline
post #9 of 25 Old 07-14-2015
Daniel - Norsea 27
if it was a DIY job, would it help to consult the guys who spray concrete pools? They tend to spray on vertical surfaces and could give some insight to the issue.
Donna_F likes this.
Daniel
1981 Nor'sea 27,
-Paul Carvel
post #10 of 25 Old 07-14-2015 Thread Starter
boz86's Avatar
That would definitely be worth checking into.
boz86 is offline
Sailing through time with the Presqu?ile Yacht Club (The Independent Online) NewsReader News Feeds 0 07-27-2006 12:15 AM
Ferrocement Pros and Cons Dan Dickison Buying a Boat Articles 0 10-06-2001 08:00 PM
Considering Ferrocement Don Casey Buying a Boat Articles 0 03-22-2001 07:00 PM
Considering Ferrocement Don Casey Gear and Maintenance Articles 0 03-22-2001 07:00 PM
Insuring a Ferrocement Boat Mark Matthews Buying a Boat Articles 0 09-06-2000 08:00 PM
