Lugs'l or Gaff - SailNet Community
 2Likes
post #1 of 15 Old 03-21-2017 Thread Starter
Lugs'l or Gaff
I'm building my second boat in 35 years. The first one was a 17' canoe, this one is going to be a 14' Maine Peapod with a sail.
My question is, the plans come with a Lugs'l.,. Should I build it with the lug or change it to a gafff...
Any thoughts would be appreciated
NaClH2O is offline
post #2 of 15 Old 03-21-2017
Re: Lugs'l or Gaff
I would think that changing from lug to gaff rig might mean moving the mast (depending on which style lugs'l was used)
Turnin Turtle is online now
post #3 of 15 Old 03-21-2017
Re: Lugs'l or Gaff
If the original design is lug, balanced or standing, the mast location including partners and other structural members will be forward of the location for a gaff rig. The lug may or may not have an unstayed mast, the gaff probably will have a stayed mast and forestay with headsail.
So changes to structure member locations and check sail plan to maintain the design sail center of effort.
Ulladh is offline
post #4 of 15 Old 03-21-2017 Thread Starter
Re: Lugs'l or Gaff
Yes that is what I was thinking also but now is the time to make those types of design changes.
NaClH2O is offline
post #5 of 15 Old 03-21-2017
Re: Lugs'l or Gaff
A Peapod is a good rowing boat and the lug rig is lower, less and stows better. It was genetically evolved that way for good reasons.
oysterman23 and flyrod like this.
Capt Len is offline
post #6 of 15 Old 03-21-2017
Barquito
Barquito's Avatar
Re: Lugs'l or Gaff
I must admit, I would be tempted to make the same change. Can you contact the designer? Maybe some adjustability in the centerboard would be possible after the build (if the helm is too light, or too heavy).
Valiant 32
Barquito is offline
post #7 of 15 Old 03-21-2017
Moderator
Jeff_H's Avatar
Re: Lugs'l or Gaff
You really have not given enough information to allow us to provide meaningful input. For example, most traditional Peapods were intended to primarily be rowed. Those that had a sailing rig did not have a centerboard and relied on a 'plank keel' which is simply a deeper external keel timber. Because of that, they did not sail well to windward no matter what sail plan you put on them. You rowed to windward and reached or ran under sail.
But once you add a centerboard, these are pretty efficient sailing hulls and should be able to sail pretty well on all points of sail.
So, then the question becomes how do you plan to use the boat, and does the design include a centerboard. If you plan to row more than sail the boat, a spritsail is a nice rig since it is quick to rig and quick to stow, and frankly was probably the original sailing rig if the boat had a sailing rig at all. It sails pretty well on a reach or a run and so work well with a plank keel.
A lug rig does not sail as well as a sprit rig and is prone to excitation roll when running down wind like a spinnaker and makes for a rolly ride. It also tends not point as high as sprit rig and can be higher maintenance since there tends to be a lot of chafe.
A gaff rig will generally point slightly higher than either of those two and will reach and run similarly, but the spars tend to be harder to stow in the boat when you want to row since the gaff is captive on the mast.
If the boat is one of the lighter weight, stitch-and-glue interpretations of a Peapod and has a decent centerboard and rudder design, I personally would do a sliding gunter rig which should out perform all of these, but will need you to hike more or reef sooner in a stiff breeze. I have generally concluded that sliding gunter rig can be designed to stow easier than a gaff rig.
I did want to respectfully mention that this is backward for a gaff vs lug cat rig. The position of the mast on a cat rigged gaff rig would need to be farther forward than that of a cat rigged lug rig since part of the lug sail is forward of the mast on a lug rig. But if a headsail is added then the rig would need to move aft. At that point, the sliding gunter rig would be a no-brainer.
Jeff_H is online now
post #8 of 15 Old 03-21-2017 Thread Starter
Re: Lugs'l or Gaff
Thank you for your comments. The boat is a 14' Maine Peapod, it has a centerboard. Also she will have white oak keel and frames. The planking will be western red cedar. She should weigh a little more than 200 lbs.
NaClH2O is offline
post #9 of 15 Old 03-22-2017
Moderator
Jeff_H's Avatar
Re: Lugs'l or Gaff
I personally would probably build this as a cat rig with a sliding gunter mainsail. The problem with a sloop rig is the mast would need to move aft so far that you would lose the ability to easily switch from rowing to sail and back again. The gunter rig would allow the boat to point a little higher and sail better when close reaching, making the boat nice to sail. 200 lbs is probably a little lighter than a historic peapod and heavier than the modern stitch and glue ones. My only other concern would be if you are doing carvel planking which does not tolerate drying out as much as other planking techniques. I would be tempted to double plank, or use WEST System for the planking if you don't intend for the boat to live in the water.
post #10 of 15 Old 03-22-2017 Thread Starter
Re: Lugs'l or Gaff
I just stopped at the sail shop and he said to just make it a gaff sail.
Only need to make a couple small changes and don't need to move the mast or centerboard.
He said that it should also improve the handling of the boat...
NaClH2O is offline
Crimping 2/0 lugs SteveInMD Electrical Systems 7 08-21-2009 06:19 PM
Crimping lugs onto 4- and 6-gauge wire LookingForCruiser Gear & Maintenance 5 06-13-2009 04:43 AM
main sail lugs breaking, why? papasailor General Discussion (sailing related) 7 07-01-2008 04:36 PM
Crimping battery lugs scosch Gear & Maintenance 19 12-03-2007 09:43 PM
Gaff rig vs ??? gharr8 General Discussion (sailing related) 6 10-01-2007 10:00 PM
