-   Sailboat Design and Construction (http://www.sailnet.com/forums/sailboat-design-construction/)
-   -   Two piece mast? (http://www.sailnet.com/forums/sailboat-design-construction/37830-two-piece-mast.html)
L124C 10-20-2007 04:02 AM
Two piece mast?
I took the mast boot off the keel stepped mast of my Yankee 30 sloop. I discovered what appears to be a splice in the mast :confused:. About midway at the partners, there is a horizontal joint in the mast with several rivets above and below it. I can only assume the rivets join the two sections of mast to an inner sleeve. Has anyone heard of anything like this? If so, what would be the purpose of the spice? Someone suggested that the mast might have been tabernacle mounted at some point, but I find this hard to belive in a boat that was designed to be keel stepped. In addition, I see no signs of a tabernacle on the deck. Any ideas?
Sapperwhite 10-20-2007 04:09 AM
Masts can be spliced.
If its right at the partners, deck level, it could be the the boat was retrofitted to have a keel stepped mast. I don't know how Yankees were rigged, deck or keel stepped. It could also be a repair, was the boat ever dismasted?
Tartan34C 10-20-2007 07:12 AM
There is a limit to the length of an aluminum extrusion so joints are common. You will usually find a joint at the partners or spreaders because the mast is more in compression then bending at those places. A joint doesnít always mean a change or repair was made it may only indicate that the section used for your boat came standard in a length that needed a piece spliced in to be long enough for your mast. Properly done a splice isnít any reason for concern.
All the best,
Robert Gainer
sailingfool 10-20-2007 11:05 PM
54 Attachment(s)
Your 30 doesn't have a very big rig so I expect that the mast was repaired at some point with a joint. Ut can be a lot cheaper to splice a peice in than to repklace the entire mast. I've seen plenty of one designs with spliced masts and I wouldn't think it anything to worry about unless there were any evidence of some type of problem developing.
