11-02-2007
Zanshin-
If the ground is deep..then you probably won't hit it.
Originally Posted by Zanshin
Haffiman37 - Umm, what do you think this means:
The reason that lots of aircraft have not arrived is identical to the cause that many boats have not arrived. Both hit the ground in manners (and angles) that the designers didn't cater for. In the case of boats, that ground is usually very wet and deep.
