Blogs
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
Old 11-02-2007
HoffaLives's Avatar
HoffaLives HoffaLives is offline
HoffaLives is on a distinguished road
O' my God!!!
My boat is listing! About ten degrees to starboard. I've checked the water tanks and they are both full. There's no gear or stowage that's different from before she was pulled, and yet she is listing. It's lower about 4-6" inches on the starboard side. WTF? If they had blocked it wrong and it sat on the hard for 6 weeks like that can it distort the hull enough that the keel leans off centre? What else other than off-balance load or the keel can make a 16,000 lb boat list like that?
AHHHHHHHHH!
Old 11-02-2007
bestfriend's Avatar
bestfriend bestfriend is offline
Hitchin' a ride
bestfriend is a jewel in the roughbestfriend is a jewel in the roughbestfriend is a jewel in the rough
whats your depth? are you sitting on the bottom at the yard or in your usual slip?
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 11-02-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
You could be listing if the water is shallow enough and the boat is resting on the keel. It wouldn't be great for the boat, but that is one possible explanation, as BF has pointed out.
I don't believe that even blocking your boat wrong would distort the hull at all. The boat you have has a pretty thick hull IIRC.
Are you in your usual slip? If not, what does the fathometer say??
If you're new to the Sailnet Forums... please read this POST.
Old 11-02-2007
HoffaLives's Avatar
I haven't checked the depth, but I can see it's way deeper than the keel. This boat is a shoal keel, BTW. In fact I had to motor to a temporary slip to clear the travel lift dock. It's the same on both slips.
Old 11-02-2007
AjariBonten's Avatar
AjariBonten AjariBonten is offline
Aquaholic
AjariBonten is on a distinguished road
Not to be Captain Obvious or anything, but you've checked you bilges, right?
I got an Old Fat Boat
She's Slow But Handsome
Hard In The Chine, but Soft In The Transom
I Love Her Well, And She Must Love Me
But I think It's Only For My Money
..... Gordon Bok
Old 11-02-2007
bestfriend's Avatar
Hitchin' a ride
Heres another obvious dumb question, but I do not have a boat next to me on windward side. When the wind kicks up, it blows around the next boat and onto my port side causing a slight list, about 4-6 inches like you said. When we switched marinas it really freaked me out until I realized it was just the wind.
Vaya con Dios
Old 11-02-2007
HoffaLives's Avatar
No, she's not on the bottom. I was pushing her around to get her to fit in this small slip. I checked the bilges and not much in there either. I don't understand it either, but it would take hundreds of pounds to create that list.
And this slip is sheltered from the (small breeze), and 90 degrees different angle from the travel lift slip. Same list.
Old 11-02-2007
Aquaholic
Well, if you're not shipping water, take a breather and sleep on it.
unless they moved yor engine 12 or 14 inches to one side what else could they have done???
..... Gordon Bok
Old 11-02-2007
Sailormann Sailormann is offline
Here .. Pull this
Sailormann will become famous soon enough
Check the keel bolts when you haul her. Not likely that your hull is distorted but if they dropped it then the keel bolts could be bent. Take pictues of the list just in case...
Also - what side is your fuel tank on ? Is it full ? There's a fair amount of weight there. Did they take out the batteries ? Are they back where they're supposed to be ?
Old 11-02-2007
bestfriend's Avatar
Hitchin' a ride
check the plumb of your mast.
Vaya con Dios
Display Modes
vB code is On
Islamism sailaway21 Off Topic 323 07-18-2008 03:44 PM
I am a single handing GOD! jbarros General Discussion (sailing related) 24 07-01-2008 10:06 AM
Future Seasickness Warning or Not FullandBy General Discussion (sailing related) 33 09-30-2007 09:24 AM
God help me, I can't help it... I want one! Looking Buying a Boat 54 03-25-2007 11:07 PM
A Sailor's Guide to the Gods John Kretschmer Cruising Articles 0 04-26-2001 08:00 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
