Been looking through literature on new Wauiqueiz's (e.g., PS 47, PS 43, etc.). They indicate their hulls are cored and vacuum infused, but there is no specificity with respect to core materials below waterline. Does anybody know if they're building with the core materials below waterline?
Sailing winged keels since 1989. 1.20.09 Bush's last day the end of an error !! Hopefully we still have a constitution and economy left by then.
"Compassion and tolerance are not a sign of weakness, but a sign of strength." The Dalai Lama
good planets are hard to find-- a song by steve forbert
I have but one lamp by which my feet are guided, and that is the lamp of experience. I know no way of judging the future but by the past.-- Patrick Henry.
THE HULL is laid up with the greatest of care, and bisphenolic resins in the outer layers help protect your boat in the long run. Today, Wauquiez also uses the « infusion » process, which not only helps protect the environment, but also ensures an optimum resin /glass-fibre ratio, as well as an exceptional stiffness (balsa sandwich) and important weight savings.
Since they don't specify not using the balsa sandwich below the waterline, I would guess that the hull is cored. Most builders will specify if they don't use core materials in the hull below the waterline.
Sailingdog Telstar 28
If you're new to the Sailnet Forums... please read this POST.
My boat is cored under the water line above the water line, on the deck, inside and outside....the only part not cored is a foot wide strip runing from the bow to the stern along the boat's lenght...I don't see my cored hull being a problem...
Nothing wrong with a marine plywood, epoxy saturated, fibreglassed core - as long as you know what you are dealing with and don't puncture it. That's what my decks are - hull is solid glass.
