Originally Posted by KeelHaulin
I agree with Jeff_H that double mainsheets instead of a mainsheet/traveler/(preventer) would be a big PITA for most cruising boats. In addition I think the sheet loads would be higher to get the correct upwind trim at higher windspeeds because they are pulling at a diagonal instead of vertically against the boom.
Glad to see you were paying attention
: that picture was purely to show "the system" from above. You can't get the whole set-up in frame unless it's from above.
You can see that the farther out the boom is from center, the more vertical the pull downward. The key is that the mainsheet is *still on* and functioning. You slack it off to use the dual semi-preventer-things to make the gybe, and then you can move the traveller cars and tension the mainsheet afterwards. The "working preventer" then works exactly like the old style vangs that would have a shackle on the lower block taken to the rail.
EDIT: We were likely making 6.5 knots under a No. 3 alone at that point; I recall that a strong 25-30 knot northeast wind pushed us west south west from Cobourg to Toronto in just under 10 hours, a record for that boat. We had to hoist the main later in the day to keep up speed
I have found this simple and relatively inexpensive system has made downwind work considerably safer, because the purchase provided means you can ease with one hand and tension with the other. Even in 35 knots, I can keep a reefed main moving slowly to the new course, saving damage, noise and possible injury (a guy was killed here in a crash gybe a few years back because preventers were not rigged).
Of course if you broach or otherwise screw up, these preventers could save your boom and main. Admittedly, they are not as useful in this as the usual preventers run from boom-end forward to the bow and back to the cockpit, but they are good enough as they are for my purposes.
