Blogs
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
Old 11-16-2007
Stryker72's Avatar
Stryker72 Stryker72 is offline
Stryker72 is on a distinguished road
Home built Daysailers
Lately I have had the urge to build a small daysailer, about 14-18' or so. There are many plans available, but what is the quality of these boats (providing they are built correctly)? Do plywood boats holdup? Is anyone sailing a home build boat?
Because of the lake I sail it gets pretty mucked up and weedy by the peir I am looking for a centerboard with a draft less than 9" when the CB is raised.
Some of the plans I have been looking at are:
Selway-Fisher Petit Brise
Selway-Fisher Highlander 16
Selway-Fisher Lynx 14
Hartley 14
Old 11-16-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Many of the stitch-and-glue plywood boats are excellent little boats, and relatively easy to make. Properly built, they're also fairly low maintenance, far lower than a wooden boat would be. One good magazine for you to look at is Small Craft Advisor. They have a lot of articles on just these same kind of boats, although their focus isn't strictly on sailing.
While I'm not sailing on a home-built, I have many friends who do. The sailing characteristics of the boats really depend a lot on the design, the build quality and you... since your body weight is a significant portion of the ballast.
—Captain Malcolm Reynolds, Serenity (slightly edited)
If you're new to the Sailnet Forums... please read this POST.
Old 11-16-2007
gershel gershel is online now
gershel is on a distinguished road
Sailingdog is right about stitch & glue boats, check out this site.
http://www.clcboats.com/products.php...3d525169320a7/
Old 11-16-2007
Sailormann Sailormann is offline
Here .. Pull this
Sailormann will become famous soon enough
I think that it's about the best way to learn and think you should go for it. Maybe a kit would be a litle easier if you've never done it before ???
Check out:
http://www.glen-l.com/
http://www.rainbowboats.com/postnuke/index.php
http://www.bateau.com/proddetail.php?prod=AD14
Old 11-16-2007
another good site is boatbuilder.org.
Old 11-17-2007
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Sailor
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
We built that little 11.5' sailing pram in the "avatar" photo you see above next to my name. Stitch and glue, plywood/fibreglass/epoxy composite. Smaller than what you're thinking about, but similar construction concept. Plywood/'glass is a great material for small boat construction. However, the weight eventually does add up and if you go a whole lot larger than what we built you are no longer in the car-toppable realm, if that's what you're after when you say "daysailer". I like the looks of the designs you posted above, but I think most of them would require a trailer.
I second the suggestion to consider a kit if you don't have a lot of experience or tools. Make sure you have plenty of space for the build. Don't forget you'll need to flip the hull several times during construction and will need clearance on all sides (including above) to do this. Good luck to you.
Old 11-17-2007
In Small Craft Advisor this month, they have a good article about plywood stitch and glue boats... and how they can often be lighter than their fiberglass counterparts. They've got a 15' 5" sailboat that is about the same weight as a smaller fiberglass Laser sailing dinghy, but can handle four adults.
Old 11-17-2007
Faster Faster is offline
Just another sailor
Faster will become famous soon enoughFaster will become famous soon enough
I can testify as to the Hartley designs... nice stable forgiving boats with a centerboard that satisfies your shoal draft requirements. Don't think they are stitch & glue designs, though.
As to the quality - these are just designs. The final overall quality is going to be up to the builder.... YOU!
Old 11-22-2007
paulk paulk is offline
paulk is on a distinguished road
A Norwalk Island Sharpie also fits with your shallow draft/easy construction needs. Their designer, Bruce Kirby, is better known for the Laser and several other boats. He often has good ideas.
http://www.norwalkislandssharpie.org/
Display Modes
vB code is On
The Cruising Life, by Jim Trefethen, and Cruising Financials Jim H Cruising 85 12-09-2007 11:40 PM
Remembering Bill Tripp GoodOldBoat Seamanship Articles 3 11-15-2007 11:03 AM
Grampian G28 USCGRET1990 Buying a Boat 13 06-12-2007 08:34 PM
What educational books would you recommend Saasaan Learning to Sail 31 02-15-2007 01:08 PM
home built dink maestro Gear & Maintenance 10 10-03-2003 10:38 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
