Blogs
Boatbldg & Repair
Galley
Hardware
Interior
Plumbing
Tlr & Wtrsprts
Videos
Go Back   SailNet Community > General Interest Forums > Sailboat Design and Construction
User Name
Old 11-30-2007
twofish81 twofish81 is offline
twofish81 is on a distinguished road
Lightbulb Iron Keels Versus Lead Keels
Dear all,
Can anyone please advice what are the pro and cons for both Iron Keels and Lead Keels? Besides the highmaintainance cost of iron keels, what are the advantages for iron keels?
As I know iron price is 6 to 8 times lower then lead, and regarding about the environment issue now a days, most of the people is moving away from lead keels to iron keels.
I'd really appreciate the advice from you guys that have so much experience.
thank you
Regards,
Clarence Leong
Old 11-30-2007
JohnRPollard's Avatar
JohnRPollard JohnRPollard is offline
Sailor
JohnRPollard has a spectacular aura aboutJohnRPollard has a spectacular aura about
Clarence,
You pretty much covered it. The reason iron is used is that it is less expensive, which to the best of my knowledge is the ONLY advantage to iron. But it's a false economy in my book. Iron can be a costly nuisance/headache to maintain in the long run. Also, for an external ballast/bolt on keel, the iron keel will require more volume (thickness) than a comparable weight lead keel, so there will likely be diminished performance at the same draft and/or the designer will have to resort to keel appendages like wings, etc.
I think, however, that you are mistaken about the move away from lead. Most quality builders continue to use lead for ballast and would not even consider using iron.
Old 11-30-2007
Faster Faster is offline
Just another sailor
Faster will become famous soon enoughFaster will become famous soon enough
You should do a forum search, this topic has been discussed extensively before.
Another disadvantage of an iron keel is its reluctance to absorb impact. Lead is soft enough to give to a collision with a rock or whatever, often becoming misshapen... but that absorbs quite a bit of energy which means less potential damage to stringers, tabbing etc in the area behind the keel. The Iron keel has no give and transfers all that energy quite (too) efficiently.
However job one is to avoid such obstacles, and living with an iron keel is not so bad in these days of effective epoxies for encapsulation, which greatly minimizes the maintenance issues.
Also you should avoid posting the same question in two forums.....
Sponsored Ad
Old 11-30-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Any reason you posted this exact same topic twice????
If you're new to the Sailnet Forums... please read this POST.
Old 11-30-2007
Thank you for all the valuable informations. How can I end this post and stick to one as Im very new to this forum. Sorrry for posting twice for the same topic.
Display Modes
vB code is On
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 07:52 PM
Fixed or swing keel, which is better? TimG2 General Discussion (sailing related) 15 03-20-2008 05:36 PM
Iron Keels Versus Lead Keels twofish81 Gear & Maintenance 14 12-02-2007 02:58 PM
Full Keel Vs. Fin or Modified Full Keel AjariBonten Sailboat Design and Construction 37 11-15-2007 11:26 PM
Fin Keel or Shoal Keel acmecoyote General Discussion (sailing related) 7 11-07-2002 10:34 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
